Reverting to previous revision might need to disable Wiki in some cases
Hello!
Probably this works as designed. I just would like to clarify one case (sorry, unable to reproduce it on try due to insufficient TL):
  1. Write a new topic.
  2. Wait 10 minutes.
  3. Edit topic.
  4. Wait 10 minutes.
  5. Convert topic to Wiki.
  6. Edit topic.
  7. Click to Revisions sign at the top of the topic (important: while the topic in Wiki mode)
  8. Find the revision which was created before switching to Wiki mode.
  9. Click ‘Revert to revision X’ button:
  10. The message appears:
The current version is same as the version you are trying to revert to.
The solution is to switch the topic back to simple mode (non-wiki), after that it is possible to revert the topic to selected revision.
I think the behaviour is not quite friendly, because the message is not informative in this case :slight_smile: .
