Right to left icon position for right to left languages
(Simon Cossar) #1
To improve the usability of right to left sites, I would like to to reverse the position of the font icons and any text node that may immediately follow them. I see that this can be done in a plugin by overriding the handlebars templates, but that will involve overriding a lot of templates.
Are there any better ways to do this?
#2
we have this poroblems
//discourse-meta.s3-us-west-1.amazonaws.com/optimized/3X/b/4/b4559aa8aa63fdb94c97831c872703a675d2e6f7_1_690x118.png
(Simon Cossar) #3
In the Discourse templates the icons come before the text. For a right to left site the text needs to come before the icons. It is easy to override the templates in a plugin, but we will then be responsible for maintaining the templates if they are updated in the Discourse core.
(Sam Saffron) #4
Can’t it simply be floated right?
(Simon Cossar) #5
Floating the icon to the right will still leave it to the left of the text. Ideally it would come before the text - the same way it does in a ltr language.
(Kane York) #6
Hmm, does anything change if you apply this CSS?
  direction: rtl;
(Simon Cossar) #7
For rtl languages the styles in rtl.scss work quite well. We went through them today and fixed everything that looked weird.
I don’t think the icon/label problem can be easily fixed with css. They are written in the wrong order for rtl languages. I don’t know how big of a problem it is for usablilty
(Mittineague) #8
Is it a matter of position or orientation or both?
(Simon Cossar) #9
Actually it seems to work the way it should in most cases. I wasn’t understanding how right to left works. Thanks.
(Kane York) #10
Found the fix.
.topic-statuses {
  float: none;
  display: inline-block;
Will submit a PR…
(Simon Cossar) #11
Great!
The problem I was finding with the icon position was a mistake on my part. The way I was thinking, everything in a rtl language would have to be written backwards.
We found quite a few rules that need to be added to rtl.scss. Should each rule be submitted as an individual pull request?
(Robin Ward) #12
If you want to package up a few rule into one PR that’s fine by me!
