# Rotating Composer Placeholder
**URL:** https://meta.discourse.org/t/rotating-composer-placeholder/393740
**Category:** Theme component
**Tags:** composer
**Created:** [January 18, 2026, 9:57am UTC](https://meta.discourse.org/t/rotating-composer-placeholder/393740 "2026-01-18T09:57:56Z")
**Posts on this page:** 9
**Page:** 1
<div class="post-metadata">
### Author: ![Ethsim2](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/ethsim2/32/522255_2.png) [@Ethsim2](https://meta.discourse.org/u/Ethsim2)
#### Post date: [January 18, 2026, 9:57am UTC](https://meta.discourse.org/t/rotating-composer-placeholder/393740/1 "2026-01-18T09:57:56Z")
</div>
| :discourse2: | **Summary** | **Rotating Composer Placeholder** adds dynamic, rotating placeholder text to the Discourse composer, showing a different prompt each time the composer is opened. |
| 🛠 | **Repository Link** | [https://github.com/Ethsim12/discourse-rotating-composer-placeholder](https://github.com/Ethsim12/discourse-rotating-composer-placeholder) |
| 📖 | **New to Discourse Themes?** | [Beginner’s guide to using Discourse Themes](https://meta.discourse.org/t/beginners-guide-to-using-discourse-themes/91966) |
Install this theme component
> As this is an **unofficial theme component** maintained by me,
> #Support, #Contribute > Bug, #Contribute > UX, and #Contribute > Feature requests can be made in this topic here on Meta.
### Features
- Rotates the composer placeholder text each time the composer opens
- Works for:
  - replies
  - new topic composer
- Fully configurable via **theme component settings**
- No plugin required
- Client-side only (safe and lightweight)
- Uses modern `api-initializers`
## Install
1. In Discourse Admin, go to:
**Admin → Appearance → Themes & components → Components → 3 dots**
2. Click **Install**.
3. Choose **From a git repository**.
4. Paste this repository URL and click **Install**.
## Enable the theme component
Installing a theme component does **not** activate it automatically.
You must attach it to a theme.
1. Go to:
**Admin → Appearance → Themes & components → Components → Rotating Composer Placeholder**
2. Click your **active theme**
(for example: “Default”, “Desktop”, or your custom theme).
3. Press the **green tick box**.
4. Refresh your browser.
Once enabled, the component will immediately apply to that theme.
## Configure the component
1. Still within the theme component’s page.
2. Edit the `rotating_placeholders` list.
Example values:
- `What did you try? Include steps to reproduce.`
- `One idea per reply. If it’s a new issue, start a new topic.`
- `Please include: expected result, actual result, and any errors.`
- `Tip: paste logs inside ```triple backticks```.`
Notes:
- Each list entry becomes a possible placeholder.
- Empty entries are ignored.
- If the list is empty, a default placeholder is used.
### Known limitations
- UI-only enhancement
- Does not affect post content
- Placeholder rotates when the composer opens
- Future composer refactors may require minor selector updates
### Compatibility
- Designed for modern Discourse versions
- Recommended minimum: **Discourse 3.2+**
- Uses supported theme APIs only
### Author: ![Canapin](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/canapin/32/119591_2.png) [@Canapin](https://meta.discourse.org/u/Canapin)
#### Post date: [January 18, 2026, 12:08pm UTC](https://meta.discourse.org/t/rotating-composer-placeholder/393740/2 "2026-01-18T12:08:02Z")
</div>
Can you share examples of use case?
### Author: ![pfaffman](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/pfaffman/32/120154_2.png) [@pfaffman](https://meta.discourse.org/u/pfaffman)
#### Post date: [January 18, 2026, 12:19pm UTC](https://meta.discourse.org/t/rotating-composer-placeholder/393740/3 "2026-01-18T12:19:53Z")
</div>
I think the examples do a good job demonstrating the use case. There are lots of things to consider when composing a message. If you put just one, it’ll soon be ignored. If you put all of those, no one would read any of them. Having a different one each time increases the likelihood that someone might read and consider one of them.
You could also put funny Easter eggs.
#### Post date: [January 18, 2026, 12:44pm UTC](https://meta.discourse.org/t/rotating-composer-placeholder/393740/4 "2026-01-18T12:44:11Z")
</div>
Oh , right, I didn’t even see the examples.
![Game of Thrones: The Walk of Shame](https://global.discourse-cdn.com/meta/original/4X/0/9/8/0982f7aeced740acde40f5cb0a2414f6c8bc3a3d.webp)
#### Post date: [January 18, 2026, 4:16pm UTC](https://meta.discourse.org/t/rotating-composer-placeholder/393740/5 "2026-01-18T16:16:23Z")
</div>
Thanks! One nice bonus I found is that the component works cleanly with the **rich text composer** as well - the placeholder still rotates correctly there.
Since it hooks into the composer lifecycle rather than editor-specific internals, it doesn’t rely on Markdown-only selectors, which helps keep it compatible across composer modes.
If Discourse refactors the editor again in future, this should hopefully keep the surface area for breakage fairly small.
### Author: ![Lilly](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/lilly/32/575047_2.png) [@Lilly](https://meta.discourse.org/u/Lilly)
#### Post date: [January 18, 2026, 4:32pm UTC](https://meta.discourse.org/t/rotating-composer-placeholder/393740/6 "2026-01-18T16:32:56Z")
</div>
nicely done @Ethsim2 👏
Perhaps category specific placeholders could be a useful addition? (although I sort of recall there may be a component somewhere that already does that feature)
> [@pfaffman](#):
I actually want to use this to make them ALL funny on one of my forums…
_“WHAT IS WRONG WITH YOU? CAN’T YOU READ???”_
_“What’s the difference between someone who doesn’t search before posting and a lazy arse?”_
_"If you are reporting a bug, please first make sure it is not an arachnid. "_
_“What is the airspeed velocity of an unladen swallow?”_
#### Post date: [January 18, 2026, 4:46pm UTC](https://meta.discourse.org/t/rotating-composer-placeholder/393740/7 "2026-01-18T16:46:08Z")
</div>
You’re welcome! 🙂
Category-specific placeholders is a really nice idea - I can see it being especially useful for “Support / Bug” vs “General chat” categories, where the prompts you want users to see are completely different.
Implementation-wise, the composer context usually provides enough signal to do this cleanly:
• New topic: key off the selected `categoryId` in the composer model
• Reply: derive the category from the topic context
So a possible v1 could look like:
• a theme setting mapping `category_id` → placeholder list
• fallback to the global `rotating_placeholders` if no category match is found
If you remember the existing component you’re thinking of, I’d love a link - otherwise I’m happy to add this here as a feature request and gauge interest (and avoid duplicating work if it already exists).
Also - your “ALL funny” list is exactly the kind of chaotic good I had in mind 😂
(I’d probably still mix in a few serious ones, so the occasional useful reminder sneaks through!)
### Author: ![Moin](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/moin/32/554653_2.png) [@Moin](https://meta.discourse.org/u/Moin)
#### Post date: [January 18, 2026, 6:28pm UTC](https://meta.discourse.org/t/rotating-composer-placeholder/393740/8 "2026-01-18T18:28:15Z")
</div>
> [@Lilly](#):
There is [Topic Template Placeholder Text theme component](https://meta.discourse.org/t/topic-template-placeholder-text-theme-component/149053) where you can use the category template as the placeholder
#### Post date: [January 18, 2026, 6:37pm UTC](https://meta.discourse.org/t/rotating-composer-placeholder/393740/9 "2026-01-18T18:37:41Z")
</div>
Thanks! That’s a really helpful link.
That component (“Topic Template Placeholder Text”) is slightly different to what this one is doing: it uses the category topic template as the placeholder (so the placeholder is category-specific, but it’s essentially the template content).
This theme component rotates through a list of short prompts each time the composer opens (and it applies to replies as well as new topics). So “category-specific placeholders” could still be a useful addition here if we want rotating per-category lists with a fallback to the global list - especially for “Support/Bug” vs “General chat”.
But if someone’s goal is specifically “show my category template as placeholder”, that other TC already solves it nicely.
