Ruby2.6 required for 2.4.1?
Hi,
while updating to 2.4.1 I noticed, that ruby2.6 is required now:
Fetching gem metadata from https://rubygems.org/.........
actionview_precompiler-0.2.2 requires ruby version >= 2.6, which is incompatible with the current version, ruby 2.5.5p157
Is this intended? On github ruby2.5+ is still listed as requirement.
Thanks,
Alex
We will certainly fix the documentation up, it is out of date we require ruby 2.6.5
That’s a pitty. The current stable version of debian (buster) is shipping with ruby-2.5.1.
Why is this a problem? Could you elaborate?
I am currently using discourse without docker and with the ruby version from the package manager. I think I have to use rvm now…
(Yes I know, the only officially supported installs are docker based, but I currently cannot use docker.)
Updated the documentation.
Can you elaborate here?
Hi @techAPJ,
Also redis version should be updated? Minimum is 4.0.0 as of v2.5.0.beta1 if I’m not mistaken. (More concretely https://github.com/mperham/sidekiq/tree/v6.0.5#requirements)
Cheers,
Ismael
That is correct. Updated required version for Redis as well.
