The problem isn’t exclusive to Discourse, since @tgxworld reproduced it with a Docker container containing almost nothing but runit. (Although Discourse might be able to make a workaround.)
Runsv hanging on Docker container shutdown
Here comes a new challenger:
http://engineeringblog.yelp.com/2016/01/dumb-init-an-init-for-docker.html
For anyone else who needs a working solution, I can confirm that docker kill <container name>
successfully stops and kills the process. Not elegant, but it works and you can be in eternal discourse heaven.
Thanks. I must say, this issue is a pain in the backside when trying to rebuild containers.
Couldn’t agree more, hopefully it gets fixed sometime in the near future. Luckily there is a temp fix… kind of annoying having to reboot a node if docker hangs though.
Can you try adding this to your template and rebuilding?
run:
- exec: cd /sbin && wget https://github.com/krallin/tini/releases/download/v0.8.4/tini-static
- exec: chmod +x /sbin/tini-static
- exec: mv /sbin/boot /sbin/boot_image
- file:
path: /sbin/boot
chmod: "+x"
contents: |
#!/bin/sh
exec /sbin/tini-static /sbin/boot_image
Does the issue go away? cc @Luke
Confirm tini is running as pid zero after that change, ./launcher enter app
… ps aux
you should see tini-static.
Note if this is accepted into tini we can get rid of our boot shell script. Ability to execute a command on start and exit · Issue #28 · krallin/tini · GitHub
From DISCOURSE_SMTP_ADDRESS in discourse_docker to /var/www/discourse/config/discourse.conf
I’ll get working on it. Furthermore, I was incorrect, this is also occuring in Debian stable (jessie), I no longer think this is specific to ubuntu.
I’ve tried this, but it seems it didn’t work for me; cron
was left hanging, so I rebooted. BTW, I’ve noticed that some processes lack a shutdown script in /etc/runit/3.d/
, cron
included.
But maybe we need -g
to kill whole process groups, since we launch bash which doesn’t propagate signals, as in the example here?
So I’ve tried changing /sbin/boot
's invocation of tini
to:
exec /sbin/tini-static -g -- /sbin/boot_image
. Now I’ve been able to restart the container on 2/2 attempts!
interesting…
the way the boot script works it forwards a HUP to runsvdir if it gets a TERM which docker stop sends it. If we move to using -g we are not going to terminate the processes potentially out-of-order … hmmm
this should be simple to fix, maybe all we need is a script to kill the cron daemon in /3.d/ can you try that?
It’s very hard for me to test this stuff cause I can not repro the issue.
Note, when runsvdir gets a hup it is meant to send a term to each of its chidren.
Seems to work. I’ve added all missing scripts:
docker exec -it info1-discourse env TERM=xterm /bin/bash
cd /etc/runit/
echo -e '#!/bin/bash\nsv stop cron' > 3.d/99-cron
echo -e '#!/bin/bash\nsv stop rsyslog' > 3.d/99-rsyslog
chmod +x 3.d/*
then I’ve removed -g
from /sbin/boot
, restoring the previous content. I’ve done a few restarts, all seems fine.
But you’ll probably want to change priorities for other procs — I guess you want cron and rsyslog to shutdown after postgres and ssh, so the latter ones should change to priority 98.
As @Luke suspected, the kernel is involved — but you need the “wrong” kernel. With ubuntu 14.04, that’s a kernel from 3.13.0-72
onwards.
I’ve argued why the kernel is involved here, armed with my kernel stack trace:
Furthermore, the AUFS issue is introduced by [“mm: make sendfile(2) killable”] (mm: make sendfile(2) killable · torvalds/linux@296291c · GitHub), which was backported by Ubuntu into 3.13.0-72
— as also mentioned in Docker 1.9.1 hanging at build step “Setting up ca-certificates-java” · Issue #18180 · moby/moby · GitHub. I upgraded from -71
to -74
, and this explains what triggered this bug. @andybalholm reports upgrading to -73
, which also fits.
Besides, unkillable processes are always kernel-level bugs.
I think the init problems are just triggering the AUFS bug: IIUC the code, if a process gets a SIGKILL at the right point while writing on AUFS, it’s screwed — so we’re just replacing SIGKILL with SIGTERM. One source of SIGKILL
might be docker stop
timing out, but maybe there’s more? Now docker stop
takes 3.6 seconds, by default it waits for 10s before sending SIGKILL
Kind-of, but worse. AUFS calls an underlying write “syscall” (from kernel space) in a loop handling EINTR; with newer kernels, if a SIGKILL is pending, each loop iteration will fail with EINTR, while SIGKILL
will not be delivered between loop iterations, since the loop is in kernel space.
Looking at the bugfix might explain a bit more (or not). But beware: This part of AUFS code looks far from pretty:
I see and thank you for the diagnostics, the thing I find perplexing is that boot has this line:
trap "echo Shutting Down && /etc/runit/3 && kill -HUP $RUNSVDIR && wait $RUNSVDIR" SIGTERM SIGHUP
runsvdir
indeed sends TERMs to every process it started (I tested this a lot), so it should not be needed to add explicit stops for stuff where ordering of stop is not required. (like cron / logrotate)
http://smarden.org/runit/runsvdir.8.html
If runsvdir receives a TERM signal, it exits with 0 immediately.
If runsvdir receives a HUP signal, it sends a TERM signal to each runsv(8) process it is monitoring and then exits with 111.
I tested this and it is indeed the case … which leaves 2 options here …
- Somehow
/etc/runit/3
is returning a non 0 status code (we got to fix it so it does not matter what happens it runs)
trap "echo Shutting Down && (/etc/runit/3 || echo "failed to stop" && exit 0) && kill -HUP $RUNSVDIR && wait $RUNSVDIR" SIGTERM SIGHUP
- Somehow
/etc/runit/3
is taking longer than 10 seconds to run
Any chance you can help debugging this by changing that trap line?
When /sbin/boot is running without shell, it takes pid 1 and in my tests become unstoppable.
This is my hypothesis, and my few tests seem to confirm it
Changed
CMD [’/sbin/boot’]
For
CMD /sbin/boot
And the extra bash process prevents it from being pid 1, and the problem didn’t reproduce anymore in my test.
Hmm, but we do not specify CMD anywhere, launcher simply runs it, Dockerfiles do not have a CMD
I have to test if the official container is affected, it was in an experiment.
Changing the command exec command for
sh -c /sbin/boot/
Appears to have reduced the frequency it happens for me, but it still happened when I started and stopped the container several times. It could have been a coincidence, I’m confused with this issue.
TL;DR. Looks like that’s never worked properly – the script won’t actually exit unless you add an explicit exit
, as in:
trap "echo Shutting Down && /etc/runit/3 && kill -HUP $RUNSVDIR && wait $RUNSVDIR; exit" SIGTERM SIGHUP
Maybe, for extra safety from your concerns on failures, also stop using &&
trap "echo Shutting Down; /etc/runit/3; kill -HUP $RUNSVDIR; wait $RUNSVDIR; exit" SIGTERM SIGHUP
Using the first line was harmless (reboot still worked); but after rm /etc/runit/3.d/99-rsyslog
, restarting the container made runsv unicorn
hang using 100% CPU (with usual symptoms), so I don’t recommend it. I’m playing around a bit to fix this, starting from the 2nd line.
Explanation
I indeed hadn’t bothered checking why SIGKILL
was sent, and can’t try that in production (except at night, but I do prefer). Moreover, there’s tons of possible sources for SIGKILL
— it’s usually rather harmless, after all, so bugs could go undetected indefinitely, I thought. I didn’t expect the latent bug to lie in plain sight, and I didn’t notice it when reading the script.
I figured this is reinventing a wheel we probably shouldn’t be reinventing. So I looked at my Gitlab’s image for inspiration, and was enlightened by reading the line
trap "sigterm_handler; exit" TERM
What’s that exit
for? Turns out that’s not implied — and if it were otherwise, how would you disable the implied exit
To wit, save and run this script, and try killing it with Ctrl-c or by killing the printed PID with SIGTERM
or SIGINT
. Neither will work (you’ll only see foo
appearing), you’ll need another signal for killing (e.g. SIGKILL
echo $$
trap 'echo foo' TERM INT
while :; do :; done
On Ubuntu since 2006 and on Discourse images, /bin/sh
is dash
, not bash
. Signal handling might indeed be different somehow; docs don’t document the same behavior, but are rather incomplete. However, dash
is not designed to be a proper init process, so I don’t recommend pursuing that avenue.
Switching to the 2nd line (without &&
), and readding /etc/runit/3.d/99-rsyslog
, made redis
crash this time. I’m confused, but for now I’m giving up debugging on a production machine (though at night, where my users mostly sleep).
This has started happening to me too, running Ubuntu (3.16.0-59-generic #79~14.04.1-Ubuntu SMP Mon Jan 18 15:41:27 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
). It seems to happen every time the container is stopped, docker kill
works fine. The server was running fine for a long time – in the meantime, I only installed updates to the system and Discourse.
