Script for changing img (login modal)
As thoughtful and creative as the new login modal is I already had a custom log in and the new one is aesthetically challenging to it
As its not an icon the api icon change seemed out so I’m hoping for some help with a script?
I would like to utilize the image placement and put something else in its place, perhaps with a script change?
<script type="text/discourse-plugin" version="0.4">
  api.changeWidgetSetting('waving-hand',  'https://new/image/url')
</script>
Can anyone offer any assistance please?
Thank you!
edit:
add details
Currently I use a component to add either ads or just change the log in look
The script idea (for the /head) came from others I’m running, I’m open to other methods/ideas but prefer the ability to add custom vs icons etc
