Searching "Solved" posts
(Jenessa) #1
Hello! Thank you for all you do, I love using Discourse!
Please tell me if this is already a feature and I am just missing how to use it, but I would love a way to search the posts marked “solved” in our Discourse. It would be great if these posts popped up first when a user searched for something similar as well, or a way for users to see if there are any posts with their exact error that has been solved already.
Thanks again!
(David Taylor) #2
When searching, you can put in:solved to only show solved topics.
Unfortunately there is no way to make solved topics automatically show at the top
#3
David, by data-explorer is it possible?
(David Taylor) #4
Yes, it is possible in data explorer.
You could use the badge/data-explorer queries in the plugin’s description as a starting point, although I don’t think there’s a query listed there that will simply list solved topics:
(Joshua Rosenfeld) #5
You can also append ?solved=yes to a topic list URL to filter the view. For example, https://meta.discourse.org/latest?solved=yes will filter the homepage to only show filtered topics. https://meta.discourse.org/c/support?solved=yes will show solved topics in the #support category.
(Tobias Eigen) #6
Is there a way to use search to show only unsolved topics?
Update: yes, there is. Just add in:unsolved to the search.
(David Taylor) #7
in:unsolved should do the trick I think.
You’ll probably want to search by category as well, as all normal topics are always “unsolved” if the discourse-solved plugin is not enabled on their category
Edit: I see you figured that our already :wink:
Seeing assigned topics in advanced search
(Tobias Eigen) #8
Thanks, David! I’m thinking more about messages anyway, so am exploring e.g. to show me the messages assigned to me that are solved vs unsolved. This works quite well:
in:messages assigned:tobiaseigen in:solved
in:messages assigned:tobiaseigen in:unsolved
Now that messages can also be tagged by staff, I’d also want to add eg. tags:new+urgent to find all new, urgent messages that need handling.
Query for Unsolved Topics
