Separating Redis clusters. What’s sent into Redis? Cached views, Sessions, both?
(Renoir Boulanger) #1
Hi all,
In my cluster I have two separate Redis clusters. One that stores session data (“sessions” cluster), and another that I send expensive generated objects (“objects” cluster). The idea behind this is that I can purge completely what’s in “objects” redis nodes without risking to kick out users.
My question becomes then, is there such separation?
(Renoir Boulanger) #2
After reading related discussion in Multisite configuration with Docker, another question came up to mind.
Besides running Redis and PostgreSQL, what does the data container runs? I imagine its useless if I already configured my app node to use already managed Redis and PostgreSQL cluster?
This makes me wonder, what would be the syntax if I had more than one private IPs of Redis servers available?
Container configuration template
Here is my containers/app.yml file (the only one I need):
The following template is used;
The {{ variable_name }} would get interpolated into the Docker host server with values that woud look like this;
  • dir: /var/discourse
  • db.username: foo
  • db.password: bar
  • db.hostname: 10.10.10.2 (direct private IP to PostgreSQL server)
  • tld: webplatform.org
  • alpha_redis: ['10.10.10.3:6379','10.10.10.5:6379'] but first item would be caught and have :6379 stripped off.
# Managed by Salt Stack. Do NOT edit manually!
# location: salt.webplatform.org:/srv/salt/code/files/discourse/app.yml.jinja
templates:
expose:
  - "{{ upstream_port }}:80"   # fwd host port {{ upstream_port }}   to container port 80 (http)
params:
env:
  DISCOURSE_DB_USER: {{ db.username }}
  DISCOURSE_DB_PASSWORD: {{ db.password }}
  DISCOURSE_DB_HOST: {{ db.hostname }}
  DISCOURSE_REDIS_HOST: {{ alpha_redis[0].split(':')[0] }}
  LANG: en_US.UTF-8
  DISCOURSE_HOSTNAME: 'discuss.{{ tld }}'
  DISCOURSE_SMTP_ADDRESS: mail.production.wpdn
  DISCOURSE_SMTP_OPENSSL_VERIFY_MODE: none
volumes:
  - volume:
      host: {{ dir }}/shared/standalone
      guest: /shared
  - volume:
      host: {{ dir }}/shared/standalone/log/var-log
      guest: /var/log
Programmatic configuration of a new Discourse site
