Serving public files
(Slack-Moehrle) #1
I want to move some of our public downloads from AWS to the Digital Ocean instance that houses our Discourse forums. I can’t get it to work entirely.
I created a directory: /var/discourse/shared/standalone/uploads/files
I put in that directory a .png and a .dmg to test.
The .png works, the .dmg gives a 404.
Fails: http://discuss.cocos2d-x.org/uploads/files/CocosCreator_v1.9.0_20180313.dmg
Works: http://discuss.cocos2d-x.org/uploads/files/avatar.png
and because I wasn’t entirely sure if it was needed, I added it as an authorized extention
Can anyone see what else I might be missing?
(Cameron:D) #2
Rather than serving files through your Discourse it might be best to use this guide to serve them from a seperate domain on the host:
#3
Try removing the period from the extension. Use dmg instead of .dmg in the list of authorized extensions. Same for other extensions in your list.
(Slack-Moehrle) #4
@Cameron_D - I will try
@omarfilip - changing that doesn’t work
#5
You’re right - that doesn’t make a difference. I tested a .dmg file on my instance via normal file upload through the composer (to /uploads/default/original/2X/6/62938a16f8677633f469a3eb4a2c95753db314.dmg) and it works.
A couple things to try:
  1. Upload a test file via the composer.
  2. Use a file without extra periods in the name.
(Slack-Moehrle) #6
@omarfilip Thanks
  1. I can try this, but it wont be in the directory I want these files in
  2. Doesn’t help.
(Régis Hanol) #7
Images work because NGINX is serving them.
Attachments (ie. non-image files) don’t because they go through the rails stack and require an Upload record.
(Slack-Moehrle) #8
@zogstrip and if I fork and change these files to do what I want then I need to worry about future merges. This is a great explanation!
