Set up for some public categories and others private?
(kirsten greed) #1
Can I set up discourse so that some, but not all , categories require the user to be logged in?
(Joshua Rosenfeld) #2
You certainly can. Each category has its own security settings. By default, each category allows everyone to create, reply, and see. If you change it from everyone to trust level 0, then only logged in users can see it.
(kirsten greed) #3
I forgot to mention that I did not make the site public when I answered questions at set up , so by default people need to login. Do I need to change a setting to make the site public ? If so where is it, given that I missed the opportunity at set up.
(Joshua Rosenfeld) #4
You will need to change the setting login required to make the site public. You can also simply rerun the initial setup wizard yoursite.com/wizard - the wizard will remember all your previous answers, just change your selection about public vs private.
(kirsten greed) #5
That was easy. Thank you.
