Setting development environment
docker
(Yoni Stoffman) #1
Hey,
I’m in the process of evaluating Discourse. It is very important to me to be able to develop set of plugins and enhancement (that will later be released as open source of-course)
It was easy to set up everything and get Docker to run. However I was unable to connect to the machine using SSH. I thought it would be best to use SSHFS to mount the remote file system and develop from my pc (ubuntu 14.04)
I can log into the Docker using “sudo docker exec -i -t a15136bbd119 bash” but if I try to SSH it failed with
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Trying private key: /root/.ssh/id_rsa
debug1: Trying private key: /root/.ssh/id_dsa
debug1: Trying private key: /root/.ssh/id_ecdsa
debug1: Trying private key: /root/.ssh/id_ed25519
debug1: Next authentication method: password
root@localhost’s password:
Permission denied, please try again.
I know I’m using the correct password ( I set it my self)
  1. What am I doing wrong?
  2. Is there a better way (without installing everything locally) to set up a development environment ?
p.s.
I followed Discourse Meta but it didn’t work…
Thanks,
(Dave McClure) #2
what kind of machine are you on?
try taking a look at these topics for mac or linux:
for windows, you probably want to work in a linux vm or use the vagrant image.
