Setting up default trust level
(Steve) #1
Hi, How would I set up default TL so that no post moderation is required?
Thanks
#2
Hey Steve,
To clarify – are you wanting people that sign up to be able to post anything immediately without going into a moderation queue?
(Steve) #3
That would be correct. Just like this community.
(Jeff Atwood) #4
That is how Discourse works out of the box, so no config is needed for that.
(Steve) #5
Thanks for reply. Then it must be some updates that I have done, because now new users go into moderation until we approve them. After initial approval, they are able to continue posting. Where / how do I change back to default then? Thanks
#6
If you go to /admin/site_settings/category/trust you’ll see which settings you’ve changed (they’ll be a different colour). There is a reset button to the right of each changed setting.
(cpradio) #7
Also, since it is going into the approval queue, check the following settings under the Posting category too
approve post count
approve unless trust level
approve new topics unless trust level
