Setting up thumbnailing in Vagrant environment
(Felix R.) #1
I’ve set up the Vagrant environment from a fresh clone of the Github repository, master branch, latest commit 9e4942eeeb.
However, in the otherwise untouched Vagrant environment, Discoruse will not create thumbnails, regardless of what the actual settings “create thumbnails” and “allow animated thumbnails” are set to. I am not offered a lightbox or a clickthrough link, and the actual embedded image is the too large source image, scaled with width and height attributes.
Is there some hidden option that I need to set or some dependency? My production Docker install does not have this issue, even when updated to match head.
(Kane York) #2
You need to have Sidekiq running, which it isn’t by default in development.
