Settings search input loses focus while I type
(Anton) #1
I cannot reproduce this constantly, but it happens especially when I type fast, here is the recording:
I thought it might happen if there is only one result if my search, but then I tried “mode”, which gives 4 results, and if I type it fast, the search input loses the focus, so I cannot continue typing to refine my search.
(cpradio) #2
Are you on a laptop?
(Anton) #3
Yes. Windows 8.1 x64
(cpradio) #4
Are you accidentally tapping the touchpad and thus placing the cursor elsewhere? I know I have that problem all of the time with a laptop as I can’t repro this at all here on Meta.
(Anton) #5
Just tested with the touchpad turned off - the problem persists.
(Sam Saffron) #6
Can you make this happen on meta? Can you make it happen with any other browser?
(Anton) #7
Hm, I have no access to “Meta” admin panel settings.
Do I have such an access to “Try” instance?
(cpradio) #8
Okay, I’m confused, where exactly is this happening? What page, which search field?
(Anton) #9
URL:
/admin/site_settings/category/required
The input is the one that filters site settings while you type.
(cpradio) #10
Hmm… I still can’t reproduce this (on my dev machine). I wonder if there is a focus event that fires on load, and the page isn’t fully loaded yet for you when you start your search.
(Anton) #11
Unfortunately, this is not the case.
I did many tests, including when I waited 10 seconds and more to ensure the page is fully loaded.
Btw, I can now reproduce it constantly by typing “mode” into the search box quickly.
(Jeff Atwood) #12
I can easily confirm this, site settings search loses focus after you type. Can we prevent this from happening @neil?
(Sam Saffron) #13
While there, I really hate being trapped there with no back button after searching
(Anton) #14
Also, after clicking the Reset button to remove the search term, the focus is not returned back to the input.
(Neil Lalonde) #15
This is definitely new behaviour. Don’t know what changed… I’ll have a look.
(Neil Lalonde) #16
@eviltrout figured this out and fixed it!
https://github.com/discourse/discourse/commit/8366fcd78fd4427b6c0ee9019c9499b9d7a24616
(Jeff Atwood) #17
