Setup smtp in discourse
unsupported-install
(tonton) #1
hello all
i installed discourse on an azure server and all was configured and setup automatically
i am not a developer so i would only like to setup the general smtp with a gmail account
somewhere in the admin interface and i don’t find where to do it (like i was doing with a wordpress site)
thanks in advance if it is possible
tonton
(Matt Palmer) #2
E-mail is configured via the app.yml configuration file, not within your site settings. SSH into your machine, run cd /var/discourse, and then run ./discourse-setup and enter the correct details. Using gmail as a mail relay for machine-generated e-mail is not recommended, and violates gmail’s terms of service.
(tonton) #3
thanks matt for the informations
so i suppose it’s not possible to setup those informations from the admin panel …
thanks for gmail information too
(Jay Pfaffman) #4
That is correct. You should search here for recommendations for a mail server.
(tonton) #5
thanks jay i will, i saw a topic on the mail servers recommended
(tonton) #6
sorry to disturb matt
i managed to connect via terminal on my mac (yes i know it’s not the most accurate way i suppose)
i connected via ssh on my machine
but there is no var directory
i entered an apps directoy
i saw discourse in it,
but when i’m in the apps/discourse directory there is no ./discourse-setup command possible
could you help ?
sorry for those really beginners questions, but i usually don’t use shells and ssh to configure apps
thanks
(tonton) #7
ok matt looks like the smtp is in another directory in azure
https://docs.bitnami.com/azure/apps/discourse/
thanks for your help, i’ll take it from there i suppose !
cheers
(Felix Freiberger) #8
Please note that Bitnami-based installs are not supported and regularly cause problems, e.g. when trying to install updates.
I’d highly recommend that you backup your site and migrate to a supported Docker-based install using these instructions:
https://github.com/discourse/discourse/blob/master/docs/INSTALL-cloud.md
