Setup wizard doesn't start
Hi,
I’d like to change my home page layout, but I can’t get the setup wizard to start.
As ‘admin’ I navigate to /wizard but there aren’t any options to start. See the screenshot.
Any ideas?
Have you tried upgrading/rebuilding the app? Or you could also change your home page layout using the desktop category page style site setting.
A recent discourse upgrade required me to rebuild the app from the terminal.
Where do I find that? Is it in the yaml config file?
Here’s another screenshot with the errors reported by firefox. Does that help?
Do you have any non-official plugins installed?
In your site settings /admin/site_settings search for it:
A more specific URL would be /admin/site_settings/category/all_results?filter=desktop%20category%20page%20style
Can you also please confirm how you installed the site. Did you follow the official install instructions? If not, what method did you use?
Hi,
No, I have zero plugins installed.
Yes. The discourse installation is nearly 3 years old. A standard docker installation that I have religiously kept up to date. now on 2.5.0.beta4
Yes, I see that. But I want to make the categories page the default when a user logs in.
Ah, yes, this discourse installation is private (from the very beginning), no anonymous navigation. I don’t know if that info. might help.
Cheers.
Ah! In that case, you’re looking for the top menu site setting. You can change it there manually instead of via the wizard. If you want the Categories page to be the default, you’ll need to make it first in the list. That will likely require you to remove other entries, and then add them back (hence why we recommend the wizard).
We’d still like to get the wizard working for you though. Is there anything in /logs that lines up with the timing of your last attempt to view the wizard?
Yes! That worked
/admin/logs/staff_action_logs nothing
/logs nothing
docker logs -f app nothing
Sorry about that. Is there anything else I can do? Please let me know.
Hey, this I18n was present in a recent version of Discourse. Please do another rebuild, or visit /admin/upgrade to update to latest.
Upgrade asked me to
cd /var/discourse
git pull
./launcher rebuild app
That ended with UPGRADE OF POSTGRES COMPLETE
Then again ./launcher rebuild app that ran the rebuild you usually see.
By the way, I noticed this again.
MaxMind IP database updates require a license
Please set DISCOURSE_MAXMIND_LICENSE_KEY to one you generated at https://www.maxmind.com
Then, once the rebuild had finished
[Fri 22 May 2020 05:38:28 PM UTC] Run reload cmd: sv reload nginx
warning: nginx: unable to open supervise/ok: file does not exist
[Fri 22 May 2020 05:38:28 PM UTC] Reload error for :
Started runsvdir, PID is 2247
ok: run: redis: (pid 2259) 0s
ok: run: postgres: (pid 2260) 0s
chgrp: invalid group: ‘syslog’
rsyslogd: imklog: cannot open kernel log (/proc/kmsg): Operation not permitted.
rsyslogd: activation of module imklog failed [v8.1901.0 try https://www.rsyslog.com/e/2145 ]
supervisor pid: 2255 unicorn pid: 2285
Anyway…
Back on the website at the admin panel
2.5.0.beta4 37128d71c7
And…
The wizard now works!!! :partying_face:
