Several bugs in 0.9.6.4
(Juffin) #1
  1. Even if “Your topic is similar to” option is turned off (set to 0) still shows blue frame after a paragraph or two
  2. In mobile version - see image #2 (IOS/Android, Safari/Chrome)
  3. Recognizes safari as mobile version and loads mobile website on desktop, effectively bugging it. (saf 6.0.5)
Mobile view incorrectly detects desktop Firefox
(Jeff Atwood) #2
@eviltrout can you check point #1?
As for the rest, I suspect caching is misconfigured on your server somehow – is this for a logged in user?
(Juffin) #3
the issue resolved after setting the value to -1, but it can be confusing for someone.
yes, both are for logged users - admins.
(Robin Ward) #5
I’ve fixed 1) now :slight_smile:
(Jeff Atwood) #6
