Several post warnings
(Caue Rego) #1
Continuing the discussion from Several posts warning, keyboard shortcuts, smile faces and an immediate question about double topics in one:
I was writing my third post in the latest Jeff blog post and I got this awesome warning about “posting too much”. I can’t remember what it said exactly, but it did imply I should probably write it all in just 1 post instead.
I usually do that, but reason I went with posting several times was to keep the awesome reply feature in place. So, what is the actual recommendation for that case? I couldn’t figure it out.
Cleaner handling of multiple consecutive replies by the same user?
(Bill Ayakatubby) #2
If replying to multiple posts in one reply, use the built-in “quote reply” feature. It’ll connect the posts together.
(Caue Rego) #3
Oh, ok, now I see it working there.
So just select the text and press “quote reply”. Perfect! :slight_smile:
Is there an easier way to quote reply a whole post?
(Kane York) #4
Yes, if you reply to a post then click the quote bubble icon:
You’ll get a result like above.
(Caue Rego) #5
D’oh! Thanks! :smiley:
Looks like this can also be used to “view source” for now. :stuck_out_tongue:
