Shorten launcher outro on failure
docker
(Kane York) #1
Continuing the discussion from How do I update my Docker image to latest?:
Perhaps we should make the outro shorter? Because it seems that’s all that anyone actually copies, and it never has the actual error message in it.
(Sigurður Guðbrandsson) #2
… perhaps even send stderr and stdout to a file, then ask the user if he wants to submit the file to pastebin … that way the user doesn’t have to do anything except press “y” and [return], get the link and share the bug with his question.
(Jeff Atwood) #3
Ok but how do we make this outro shorter, exactly?
IDEA: the outro should tell people to paste the whole log or at least scroll back a ways?
(Dean Taylor) #4
If the content of the log is known to not pose a security issue then perhaps prompt to post to a secret anonymous Gist on failure…
https://developer.github.com/v3/gists/#create-a-gist
Add something like this to the bottom of a build failure?
Looks like you have a problem your log is located here: /home/bob/discourse-build.log
To create a shareable Gist link run: ./launcher share-last-build-log
(Kane York) #5
Oh right, I forgot that we could tee the output.
(Jeff Atwood) #6
Eh, we already have enough people reporting installation errors from being randomly unable to reach GitHub or RubyGems or whatever. I don’t know that we want even more external dependencies.
My proposal is easier, change
to
** FAILED TO BOOTSTRAP ** please scroll up and look for any earlier error messages, there may be more than one
Or similar. OK, making that change now.
(Jeff Atwood) #7
Adding a tee output that splits to file and console would be nice. Then we could reference it in the error message.
