Sidekiq Crashing
#1
For some reason Sidekiq keeps crashing on my website. Sometimes it could be hours before it crashes, sometimes it will crash within a few minutes of restarting. I don’t think it is anything to do with the server power, but it could be. The server has 2gb of ram and 6 cores. The community only has around 350 members, but we are gaining around new 100 members / day.
edit: In my terminal when I ssh into the server it says this
[56047.215069] Out of memory: Kill process 31507 (.ruby.bin) score 115 or sacrifice child
[57594.217344] Killed process 31507 (.ruby.bin) total-vm:4719372kB, anon-rss:356292kB, file-rss:0kb
Makes me think it is running out of ram, but I don’t see how it would use it all
(Jay Pfaffman) #2
Do you have swap? You’ll definitely need it during an upgrade.
#3
There was 1gb of swap before, so I changed it to 4gb. Any other recommendations or is that all?
(Jay Pfaffman) #4
You could try running ./discourse-setup to set the recommended memory parameters for the amount of RAM you have (or read the comments in app.yml to make sure that you followed them)…
#5
Alright i’ll check that out, thanks for your help. I was having the same issue on my previous host with sidekiq crashing as well, Hopefully increasing the swap helps.
