Sidekiq job as plugin
(Tyler Gillies) #1
Has anyone discovered a way to add a sidekiq job as a plugin?
(Sam Saffron) #2
Sure, there is an example here:
See:
(eriko) #3
So I am trying to do this with a new plugin and I have used both the example here for the blog plugin and the one for akismet. The first puts the job files in ./app/jobs and uses module Blog which I think comes from the engine the plugin also creates. The second one, akismet, uses ./jobs and the module Jobs. In both cases the job does not get added to sidekiq after I restart the app and sidekiq. Can you tell me how the job gets loaded?
Solution:
in you plugin.rb you need to load the jobs file no matter where it is like the following:
require_dependency File.expand_path('../jobs/import_users.rb', __FILE__)
(eriko) #4
So while this works it does not seem that there is anyway to see if the jobs are running other than in sidekiq/scheduler . The plug in jobs are not listed in
  • Dashboard
  • Busy
  • Queues
  • Scheduled
  • Statistic
  • Scheduler
I am creating the jobs with:
class SuspendUsers < ::Jobs::Scheduled every 1.day
Do I need them to be an another queue or get another queue displayed in sidekiq?
