Sidekiq jobs not being processed, queue building up
I have Sidekiq jobs building up in the queues without being processed. I got aware of this when Discourse notified me about >100k jobs in the admin dashboard.
In Sidekiq’s web interface I see this:
Job	                Arguments
Jobs::RunHeartbeat	[{"current_site_id"=>"default"}]
Jobs::DownloadBackupEmail	[{"to_address"=>"daniel@xltoolbox.net", "backup_file_path"=>"https://forum.xltoolbox.net/admin/backup...
The email entry was created when I attempted to download a backup; the link to the backup file was never mailed to me.
Discourse is working fine otherwise. The e-mail test succeeded. Discourse’s log shows nothing. I’ve read "Ensure sidekiq is running." when it is definitely running which prompted me to try to download a backup, but did not help to solve my problem.
This is with a non-Docker install on Ubuntu 14.04. I know this setup not supported, but maybe someone can point me in the right direction. Thanks.
While you probably won’t like this answer, the best way is to export a backup, reinstall Discourse using these instructions, and restore your backup.
I think I finally found the cause. Sidekiq is started as a custom upstart job, and I had failed to tell Sidekiq what queues to process (with -p critical -q default -q low – although I don’t even know if the default queue is really needed). Thanks to this StackOverflow answer and the Sidekiq reference.
Maybe this helps others with a similar problem. But I guess if you don’t use the Docker image, you’re bound to run into problems like this one.
I opened this PR for those wanting to reference sidekiq.yml rather than pass explicit command line arguments.
