Simple category sidebar
theme-component
(Kris) #1
This theme component allows you to add a simple sidebar to the topic list of an individual category. You’re able to add a headline, introduction, subheads, and lists containing text or links. The sidebar only appears on screens 768px or wider.
:link: Github repo: https://github.com/awesomerobot/discourse-category-sidebar
:microscope: Preview: https://theme-creator.discourse.org/theme/awesomerobot/discourse-category-sidebar (Navigate to the “General” category)
:man_shrugging: How do I install a theme component?
Configuration options
You have the ability to set a category, choose left/right alignment, set a headline, introduction text, and add items to the list. List item formatting is somewhat strict in that you need to choose text or a link — this component will not render HTML or Markdown.
(Sam Saffron) #2
Interesting use case here is that you may want to include the same component multiple times in a parent theme with different configs… (eg diff sidebars depending on category)
(Hakan) #3
Is it possible to use it in multiple categories?
(Kris) #4
I could add the option to show the same sidebar across multiple categories (or all), seems reasonable.
(Hakan) #5
Yes, it will be fine. It would be nice to even show the sidebar of that category on the topic post. Like Reddit.
Edit: I mean. Each category will look like a category category and also category widgets will appear in the topic post. I think it would be great :slight_smile:
(Pad Pors) #6
can this sidebar also be used in the latest topic list?
