Single letter italics in composer
(Andrew Waugh) #1
Putting a single letter within a word in italics doesn’t work (at least not in preview). Bold does.
Example:
Exa_m_ple
Example
I’m not sure if this is a problem in markdown itself, or specific to Discourse.
(Sam Saffron) #2
Have you looked at http://commonmark.org/
This is how the spec works, if you are not particularly happy with the spec then a discussion belongs here: https://talk.commonmark.org/ (pretty sure this is covered though)
(Vinoth Kannan) #3
In your use case you can use single asterix * as an alternative. like below
Example
Exa*m*ple
(Andrew Waugh) #4
It makes sense, when I think about it. (a filename, for example, could easily have “System_of_a_down”).
I noticed it while trying to indicate a single letter spelling mistake. I can use bold just as well as italic.
