Single-post topic should be closed when merged with existing topic
(Erlend Sogge Heggen) #1
I just merged a topic consisting of a single post with an existing topic:
https://meta.discourse.org/t/import-woltlab-burning-board-wbb-to-discourse/34495?source_topic_id=34499
Is it fair to assume that in such a case, a moderator will pretty much always want the topic to be closed? That was already my expectation, but I noticed the topic was still open after I’d done the merger.
Wrong post count in profile
(cpradio) #2
Hmm not sure. In most cases, if I’m merging two topics, I typically delete the topic that I moved all of its posts from, as closing it really doesn’t serve any purpose either…
I do agree that, I likely would either close it or delete it and not leave it open which would encourage a split discussion.
(Erlend Sogge Heggen) #3
Well, I prefer not deleting topics but rather leaving closed ones as soft redirects to strengthen a prospective internal page rank in the future.
(Jeff Atwood) #4
Deleting is always preferred, so I deleted it.
(Erlend Sogge Heggen) #5
Ran into this again just now. Merged this stand-alone post into an existing topic elsewhere:
I forgot that the original topic would remain visible & open, and before I could do anything about it the discussion had continued. My well-intentioned moderation effectively fragmented the conversation even more!
I still think merged single-post topics should be closed (and possibly unlisted) by default. It leaves a trail in case of confusion and lets the moderator decide whether it’s best to delete it entirely.
(Jeff Atwood) #6
Sure @neil can you add this to your list, a bit of special handling when all posts are split from a topic?
(Neil Lalonde) #7
It’s done. Consider it a present from me to you. :gift:
When all posts are moved, the topic will be closed.
Hide suppressed categories from "Your topic is similar to..."
