Site being served on third party domain, stealing rankings
#1
Hi,
My Discourse forum is being sub-domained by a random third party domain / hosting provider.
http://hockey.ottawateams.com/
That subdomain loads my Discourse forum but I have no idea what that domain is to begin with. How can I prevent this from happening in the future?
Title links only work if the slug is present
Old domain stealing google ranking
(Jeff Atwood) #2
What? You do not own that domain name? I don’t understand.
#3
Correct.
I don’t own that domain at all - but when I searched my site on Google to see if I was indexing properly, that site showed up instead. I have no affiliation to that site but that specific subdomain loads my site.
(Allen - Watchman Monitoring) #4
Maybe that site used to be on a server which had your IP, then it was recycled and you got it from Digital Ocean.
Getting OttawaTeams to fix their DNS, or getting a new IP from DO should fix it.
#5
That’s probably what happened. Getting a new IP is pretty bad web technique don’t you think?
(Allen - Watchman Monitoring) #6
I’d do whatever took me less time.
Maybe the IT admin at ottawateams.com is super friendly and just as glad to remove the stale A record from their dns zone?
(Sam Saffron) #8
You could set up nginx to demand host matches, that way only your domain will work
I may add a site setting / option for something like this
#9
That would be great because they are stealing my Google rankings.
Also, how do I set up the nginx temporarily?
(Logan Mathews) #10
server {
server_name http://hockey.ottawateams.com;
return 301 http://www.yourdomain.here$request_uri;
The above will redirect everything to your domain and solve your SEO issues.
#11
Hi,
What file do I place that in?
(Sam Saffron) #12
Just wait, will add a site setting for this, maybe even default on for non-multisite.
(Felix Freiberger) #13
If you do this, can you please still allow direct access by IP? Having this has been nice sometimes, e.g. for quick test installs or while waiting for DNS to propagate.
#14
Thanks for doing this! I appreciate it.
(Erik Manger) #15
@sam
When is the feature going to be released?
(Matt Palmer) #16
Hey @Erik_Manger, this fell between the cracks of getting the 1.4 release out the door. Sam has handed this off to me. I expect to have something ready for public consumption in a couple of weeks.
(Sam Saffron) #17
Technically I think the best thing to do here is just add a new ENV setting or param into our templates.
If force_hostname is true then force it using NGINX with an extra redirect rule for direct ip access.
(Matt Palmer) #18
That was one way I considered. Another, more flexible, way would be to have a site setting that specified a “domain whitelist” regex, and have a teeny middleware that checked the Host header against that site setting, and returned a 404 if it didn’t match.
I’ve started an implementation of the latter method, which I’m now going to exercise with extreme vigour. If you’d prefer the nginx-based way, @sam (or anyone else), speak now and I can easily switch to that approach.
(Sam Saffron) #19
I think NGINX is fine for now, would prefer less work done in the rails stack
(Matt Palmer) #20
Well, the nice thing about my approach is that it isn’t done in Rails, it’s done before the app, in a teeny tiny middleware. Also, based on some of the things we talked about last week, I thought it would be better if we don’t add more things that require rebuilding the docker image to change unless we absolutely have to.
(Jeff Atwood) #21
I would say this is a case where a rebuild would be expected though. As in “let me define the name of my site”, defining what the name is not is also strongly implied.
