Skimlinks JS Code Installation Error
Currently, I have installed skimlinks js code into discourse forum from below guide.
When i tested that link then it working as properly when copy link address and paste in other tab.
[Link shows as http://go.redirectingat.com/… (followed by a long referral link) ]
But when i click on that website name and it will open into next tab then its open normal link without affiliate link.
Method 1 Copy Link Address working properly from below guide, but not working when i click on that link on my forum.
Is there any setting or code need to add into discourse forum to run code properly?
I hope question will be clear.
It is unlikely this is compatible with Discourse. You would need to direct your support requests to them.
When i discuss with them, I have found out that when i click on that link with Ctri + Left Click then it’s open affiliate link.
If i click on that with only left click then its open as normal link.
I hope my query is easy to understand.
is there any setting where i have to tick mark or anything like that?
One more thing I can find that, when I click link from mobile device showing below error.
Is there anyone have same type issue?
A few of us at SitePoint have noticed this recently. AFAICT, for us anyway, it’s when clicking on a link in a deleted post. My guess is it has something to do with the link tracker not finding an id value (broken foreign key?).
Because for us it’s a Moderator-only thing, it’s not really priority.
Anyway, I think looking into the link tracker code would be a good place for you to start.
test%20271118
How to disable External Link ‘click’ tracking?
In previous version, i have found that option in “Basic Setup” tab.
I am using discourse current version is v2.2.0.beta4 +299 and could not find above option.
Has anybody disable the above option?
I get that error intermittently and it’s annoying. I’ve always wondered if I can whitelist specific external links to prevent this.
