Smileys added to older posts are displayed in text
Hi,
I’m noticing a weird behavior in Discourse. Smileys in some of our “old” posts are displayed as text and not smileys.
(I don’t know if it’s related, but we moved from a .net domain to .com and finally from http to https)
I tried to edit/save some older posts but I can’t still get see the proper smileys.
Any ideas?
Regards,
Seb
Did you try rebuilding the post HTML? use the wrench menu on the post and select that option.
Ok found it the button! it seems to fix the problem.
Anyway to rebuild HTML for all posts within a topic?
Thx
There is a rake command to rebake posts matching a string
