SMTP, Exchange Server problem
docker
email
(Hendrik Weiler) #1
Hi,
ive tried to install a discourse instance using docker.
It works so far that i got everything working except the mailing.
Im trying to use an exchange server account for sending mails.
But i always get
504 5.7.4 Unrecognized authentication type
when i try to test it inside of the admin panel.
My settings:
address	192.168.0.114
port	39
user_name	user
authentication	plain
enable_starttls_auto	false
I found this link Troubleshooting email on a new Discourse install
and tried to set the notification_email to the email adress of the email user with, since its required to send an email via exchange server:
./launcher enter app
rails r "SiteSetting.notification_email = 'discourse@yoursite.com'"
exit
But all i get always:
/usr/local/bin/rails: line 3: [: too many arguments
Im using 1.3.0.beta5
I dont know what im missing to get it working.
(Jens Maier) #2
For starters, I’m not sure why rails r isn’t working, but please try if an error occurs with
rails c
exit
exit
Regarding the mailserver problem, are you certain that the mailserver allows authentication over unencrypted connections? If enabling STARTTLS or setting DISCOURSE_SMTP_AUTHENTICATION: login doesn’t help, you will have to ask your mail server’s administrator for assistance.
(Hendrik Weiler) #3
Thank you @elberet.
Doing it with
rails c
was working and using
solved my problem.
