SMTP Mail Problems on MediaTemple DV Server
(Kirupa Chinnathambi) #1
Hi, everybody!
I’m trying to get my discourse instance to recognize my SMTP settings so that mails can be sent. My mail server is on mediatemple (DV), and I was wondering if somebody can help me figure out what I may be doing incorrectly.
In my Plesk control panel, I have set the following values:
In my domain’s e-mail account, I created a new mail username + password, and I also created a mailbox for it.
In my app.yml, here are the relevant settings I’ve specified:
  ## TODO: The mailserver this Discourse instance will use
  DISCOURSE_SMTP_ADDRESS: mail.kirupa.com         # (mandatory)
  DISCOURSE_SMTP_PORT: 587                        # (optional)
  DISCOURSE_SMTP_USER_NAME: forum@kirupa.com
  DISCOURSE_SMTP_PASSWORD: myPassword
With these settings, I am unable to send any e-mails. When I use my temporary mandrill e-mail account settings, everything works fine. Because using the mandrill settings works, I feel this issue is with my mail server.
I’ve tried the official email troubleshooting steps. I am able to telnet in using telnet mail.kirupa.com 587. Yay! Unfortunately, when I attempt to run the mailtest app, I do get the following error:
 DISCOURSE_SMTP_ settings:
 DISCOURSE_SMTP_PASSWORD = (hidden)
 DISCOURSE_SMTP_PORT = 587
 DISCOURSE_SMTP_ADDRESS = mail.kirupa.com
 DISCOURSE_SMTP_USER_NAME = forum@kirupa.com
ERROR: unable to establish TLS: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:598)
 Fix the host certificate or disable validation
I am assuming this is related to why Discourse can’t send any e-mails using my current account.
Does anybody know what I need to do differently?
Thanks,
Kirupa
(Jens Maier) #3
Add DISCOURSE_SMTP_OPENSSL_VERIFY_MODE: none to your email configuration or install a trusted SSL certificate for your SMTP server. Note that the mailtest script ignores this setting and will fail, but Discourse itself should accept your mailserver despite the invalid (self-signed?) certificate.
(Should have been a reply to @kirupa, but I done goofed.)
