SMTP Settings on Azure VM
(Chris Stephens) #1
Hi,
I’m very new to both Discourse and to Azure VMs. I have a VM set up and I have Discourse running on it fine. I am currently the only user on the system and I am having trouble finding out where to add any SMTP settings so that Discourse can send emails (thus enabling me to invite a couple of other test users to the board).
The only similar topics I can find seem to suggest editing a particular file and then issuing a command line command to restart the server. I can’t get either at the file or at any sort of command line interface in my Azure VM, so I can’t follow the recommended solution.
I am fully prepared to believe that this is all totally possible on an Azure VM and that I am jusat missing something as to how it is done.
Any help would be very gratefully received.
Thanks,
Chris
(Rafael dos Santos Silva) #2
How did you install Discourse? Did you follow the official guide? That one needs using a terminal and accessing your server with SSO, the same way you change SMTP settings.
(Chris Stephens) #3
I just clicked a link at thge Azure portal and it did it for me.
(Chris Stephens) #4
Ah, I’ve found out how to get command line access. Should be straight forward now.
(Erlend Sogge Heggen) #5
Which link was that? Could you take a screenshot of it? If it was this link:
https://azure.microsoft.com/en-us/marketplace/partners/bitnami/discourse/
…then you’re running on a Bitnami install, which we don’t officially support because they’re (currently) forking Discourse in order to install it.
