Socket connections to DBs
(improper) #1
Making my first steps with Discourse, trying to install it at uberspace.de.
The usual way there is to use socket (filesystem) connections to PgSQL and Redis, mainly for security reasons – shared hosting.
Now I had a look at discourse_quickstart.conf and found no option for sockets. Is it supported out of the box?
Sincerely,
Steffen
(Kane York) #2
If you use the Docker install, all of the encapsulation is handled for you. A LXC is created with Docker and everything runs inside of it.
Note that your first step should be to provision a subdomain for the forum. Discourse cannot run on a subpath.
Also, you shouldn’t put signatures on your posts. We have the usercard for that.
(Sam Saffron) #3
sockets work fine: discourse/discourse_defaults.conf at master · discourse/discourse · GitHub
(improper) #4
Thanks. Docker is not an option for me.
Socket for PgSQL was not a problem; for Redis I had to patch config/redis.yml and lib/discourse_redis.rb.
Seems to work now.
(Matthias Neuhauser) #5
Hi!
Can you please share your configs with me? I am about to install discourse on uberspace and I am stuck at the redis socket problem.
Would be really nice!
(improper) #6
I don’t run that setup any more. All that is left are some notes, but they don’t go into detail on Redis:
https://foodhackingbase.org/wiki/FHB:Running_Discourse_at_Uberspace
HTH.
(Kane York) #7
https://github.com/discourse/discourse/pull/2948
