Solved Button plugin does not work?
(Ray) #1
I’ve recently added the Solved-Button plugin but I’m not seeing the “Allow users to accept answers” checkbox.
Discourse Solved (Accepted answer plugin)
(Jay Pfaffman) #2
You need to enable it in each category that you want to use it in. There is also a system setting to enable it globally.
(Ray) #3
Hi Jay,
When I attempt to edit the settings in one of my categories, I don’t see the option.
This is what I’m seeing:
(Daniela) #4
Hi @rayk, could you confirm that the site setting allow solved on all topics is not enabled, please?
(Ray) #5
i can’t find that option under settings… where should that be?
(Daniela) #6
Search for solved in your site setting (your-site.com/admin/site_settings/category/required):
Do you have my same results?
(Ray) #7
getting “no results found”
(Daniela) #8
So it seems that the plugin has not been installed, can you check here /admin/plugins if you see it?
If the answer is no, you must first check your app.yml file to see if it is in the list of installed plugins
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - mkdir -p plugins
          - git clone https://github.com/discourse/discourse-solved.git
(Ray) #9
ahh, i was using a different plugin:
i’ll use the discourse-solved.git instead…
(Daniela) #10
In addition to not being the #official one, that plugin is also very old and has never been updated (last commit 4 years ago) :no_mouth:.
You were lucky that you have not broken the site by installing it. Be sure to always check here on Meta before installing something. It is possible that if a plugin has some problem, someone has already reported it.
(Ray) #11
Thanks Daniela! All good now.
(Павел Кульков) #12
Hi!
I have the same problem, but plugin installed. I see it in /admin/plugins
(Павел Кульков) #13
After clear cache and relogin its ok now.
