SOLVED: Vagrant appears not be setting a real localhost
(Gustavo Souza) #1
hello, Im trying to set up the discourse’s environment.
but after do
vagrant up
vagrant ssh
bundle install
bundle exec rake db:migrate
bundle exec rails s
everything look fine (no errors or warnings). But when I try to run http://localhost:3000 (or 4000) on the browser it is like nothing happens.
but console still show:
[vagrant@precise32:/vagrant (master)]$ bundle exec rails s
=> Booting Thin
=> Rails 4.2.4 application starting in development on http://localhost:3000
=> Run `rails server -h` for more startup options
=> Ctrl-C to shutdown server
Thin web server (v1.6.4 codename Gob Bluth)
Maximum connections set to 1024
Listening on localhost:3000, CTRL+C to stop
I’m using Ubuntu 14.04
I would be grateful, if I had some directions.
SOLVED: "The connection was reset" with Discourse Vagrant
Sporadic missing letter avatars (cache problem?)
(Matt Palmer) #2
Can you be more specific than “nothing happens”? Something will definitely happen, whether that be an error message, or a lengthy period of trying to load the page followed by a timeout, or something completely different.
A couple of things you can try, to help narrow down the cause:
  • Does netstat -ltnp as root on the host machine show port 4000 as being open? If so, by what process?
  • What happens (ie exactly what output do you get, and how long does it take to return to a shell prompt) when you run telnet localhost 4000 on the host machine?
(Mittineague) #3
Those commands always worked for me until recently, now I need to do
bundle exec rails s -b 0.0.0.0
(cpradio) #4
Yeah, that is due to the default for rails 4.2 specifying 127.0.0.1 as the only connection, the -b allows you to connect from any IP.
(Gustavo Souza) #5
You guys were amazing, thanks a lot.
telnet was showing:
Trying 127.0.0.1…
Connected to localhost.
Escape character is ‘^]’.
Connection closed by foreign host.
but -b tip solved my problems.
(Everaldo Gomes) #6
Dear @eviltrout,
I’ve installed Discourse through Vagrant and I’m testing Comments Embedding.
All seems to work fine: a topic was created on Discourse.
But, In my blog, the link “Start Discussion” points to localhost:3000
My discourse instance is accessible through discourse.dev:3000
Do you know what I have to do, when using Vagrant, to change Discourse hostname?
Many thanks!
Everaldo
(Everaldo Gomes) #7
Dear @eviltrout,
I managed to solve. Thanks!
I went to Admin -> Settings -> Developer -> force hostname
