Some French translations are missing
(Camille Roux) #1
Even if they are in Transifex, some French translations are missing in the app like:
  • fr.user.disable_jump_reply
  • fr.user.mailing_list_mode
  • fr.user.invited.create
  • fr.admin.site_settings.reset
These are quite visible so it’s annoying…
Could you update them? Thanks!
(Jeff Atwood) #2
Perhaps @techapj can guide you to the right place in Transifex to fix?
(Arpit Jalan) #3
Okay, I updated the resource files on Transifex, they must be visible now!
(Camille Roux) #4
Did you push them on Github? I still don’t see translations…
(Arpit Jalan) #5
I just sent a PR:
https://github.com/discourse/discourse/pull/2402
