Some users can't login in mobile web application
(Pad Pors) #1
some of our users can’t login in mobile web application, after they enter their user name and password, no error message is shown to them after they try to login. and the site reloads normally, but then the not-logged in screen shows again.
I got this error in the admin log:
 ActionController::ParameterMissing (param is missing or the value is empty: login) /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/strong_parameters.rb:43
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/strong_parameters.rb:437:in `require'
/var/www/discourse/app/controllers/session_controller.rb:199:in `create'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/basic_implicit_render.rb:4:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:186:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rendering.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:131:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rescue.rb:20:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications/instrumenter.rb:21:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/params_wrapper.rb:252:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/railties/controller_runtime.rb:22:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:124:in `process'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionview-5.1.4/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:189:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:253:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:31:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:50:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `each'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:834:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-protection-2.0.1/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/conditional_get.rb:38:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/head.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:149:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/session/abstract/id.rb:232:in `context'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/session/abstract/id.rb:226:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/cookies.rb:613:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:26:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:97:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/debug_exceptions.rb:59:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.9/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:36:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:26:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:16:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/remote_ip.rb:79:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/request_id.rb:25:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/method_override.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/executor.rb:12:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/sendfile.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiler.rb:174:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/message_bus-2.1.2/lib/message_bus/rack/middleware.rb:63:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:176:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:522:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/urlmap.rb:68:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/urlmap.rb:53:in `each'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/urlmap.rb:53:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in `start'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `<main>'
I would be thankful if anyone can help me understand what is wrong with our forum, so that our users can login normally.
this has been reported by two of our users, and I can’t reproduce it.
(Pad Pors) #2
hi. can this be a #bug ?
