Spaces in HTML->MD conversion from Email turns lines into code blocks
(Stephen Chung) #1
Repo:
  1. Send an email with the following:
Hi,
We have a requirement.
Something else.
  1. The email generated will have the following text/plain version:
Hi,
Something else.
  1. The email generated will have the following HTML version:
<body>
    <p>Hi,</p>
    <p>We have a requirement.
    Something else.</p>
</body>
  1. If prefer html in email is set, then the HTML version will be taken to convert to MarkDown.
  2. The MarkDown converted will be:
Hi,
      Something else.
  1. Notice that there are SIX spaces in front of the paragraph (perhaps created by the four spaces in the HTML between </p> and <p>, plus a CRLF pair. Also, the second line because a separate paragraph with leading spaces. These spaces cause the paragraphs to become code blocks.
Any way to turn off code-block indent from emails
(Régis Hanol) #2
Do you have a raw email we can use to test this?
(Stephen Chung) #3
Can I forward one to you? Not sure if forwarded will be the same as the raw one…
Or should I copy the raw stream and send to you?’
(Régis Hanol) #4
PM the raw version of the email.
