Spacing between avatar and colored background is too small
(Sander Datema) #1
You normally won’t notice this unless you select a post (blueish background) or you see a post by a moderator (topic closed, etc.)
Anyway, might want to look at that spacing.
#2
What is the problem ?
(Sander Datema) #3
Well… isn’t that clear from the screenshot? The avatar and the colored block touch each other. Doesn’t look nice.
#4
Try this :
.topic-avatar {
padding-right: 10px;
(Sander Datema) #5
Thanks, care to put that in a PR? Or shall I give it a try.
Tip: put three back tics (`) around your code to make it look nicer.
.topic-avatar {
padding-right:10px
becomes
.topic-avatar {
#6
Not need for PR you get it in admin > customize > css_html
padding 6 is good i think
.topic-avatar {
  padding-right: 6px;
(Sander Datema) #7
Than I’ll make it a PR, cause I think it should be in core.
#8
if @sam agree this change , i’ll make a PR
(Jeff Atwood) #9
I actually think the yellow bgcolor should be on the left as well. I don’t support adding extra space for this case, when staff color is exceedingly rare.
(Sander Datema) #10
You mean it should be extended so it’s behind the avatar as well? Yeah, that would work. But then the blue selection background should be extended as well.
