Specific content in editor behaves erratically
(Erlend Sogge Heggen) #1
I get a weird bug when I’m trying to paste the following text into a new reply:
http://pastebin.com/dpekiFR9
I tried pasting it into code tags but that didn’t work either.
Weirdness in action here:
When trying to post this text I get “Error: 502 Bad Gateway”.
(Robin Ward) #2
@sam could this be a draft issue?
(Erlend Sogge Heggen) #3
Have you tried pasting the text in somewhere yourself? I’m still getting the error on try.discourse.org in a different browser. But I can make new posts with links just fine. No idea what makes that post so special.
(Kane York) #4
It might be related to your [1][2] links, which you put in the wrong place. Pretty sure markdown needs them at the end of the same ¶.
(Jeff Atwood) #5
I can’t repro this, I paste the text in just fine.
edit: ooh, I take that back. When I try to edit those links into your post on the other topic I get very weird behavior. We are definitely hitting an error on the back end somewhere. Good catch.
(Erlend Sogge Heggen) #6
I just encountered this again. This time with this piece of text:
http://pastebin.com/0bfvtqbc
As usual, removing the links does the trick.
(Sam Saffron) #7
@eviltrout fixed an issue a week or so ago in this department.
Is it still the case or can we close?
(Erlend Sogge Heggen) #8
Can’t repro, appears to be fixed.
(Sam Saffron) #9
