[spoiler] tags don't work on code blocks
(Nick Winter) #1
For the CodeCombat forum, we have a lot of players posting their code to solve our levels. It would be great if we could use [spoiler] tags so that they aren’t giving away the answers to players who don’t want to see. It works with single line code:
[spoiler]`var singleLineCode = "some code";`[/spoiler]
Edit: actually, I don’t know why I missed this, but it doesn’t work on single-line code either (no code formatting).
But indenting by four spaces on multiline code doesn’t work (the spoiler works, but not code formatting):
var multiLineCode = "some code with no code formatting";
while (true)
    multilineCode += "some more code, wish it looked like code";
Surrounding with triple backticks (our preferred method) makes code formatting work, but breaks the spoiler:
var multiLineCode = "some code that should be spoiled";
while (true)
    multilineCode += "some more code, you can't unsee it";
Would love it if the spoiler tag could support code blocks!
(Jeff Atwood) #2
Good news!
You can use the new hidden/expanding support, which is included in Discourse 1.3 beta and leverages upcoming HTML 5.1 tags.
super seekrit code block
while (true)
super seekrit code span
i = i + 1
Like so
[details=super seekrit code block]
while (true)
[/details]
[details=another super seekrit code block]`i = i + 1`[/details]
(Nick Winter) #3
Awesome, works great–thanks!
(Joachim Brehmer) #4
Hi, Moderator from CodeCombat here.
I already broke it, apparently it doesn’t like nested details:
outer
Before inner
inner
Inside inner
After inner
Spaces for details again:
[details=outer]
Before inner
[details=inner]
Inside inner
[/details]
After inner
[/details]
(Jeff Atwood) #5
How is that broken? Nesting is not supported, why would you expect it to be?
(Kane York) #6
It’s a CSS bug, only on Firefox. There’s text outside a <p>.
@zogstrip I think it should be more like this:
details {
  display: block;
  &:not([open]) {
    display: none;
    summary {
      display: block;
And not details > *.
(Jeff Atwood) #7
Oh my bad if it is Firefox only, we should fix. Does work ok on mobile safari.
(Régis Hanol) #8
Thanks @J_F_B_M for reporting that issue. I just pushed a fix :turtle:
(Steven Greco) #9
I cant seem to get this to work on my site. I pulled the latest commits from git and did a rebuild app but no luck. It does not look like its recognizing the tags.
#10
Did you install the plugin?
(Steven Greco) #11
Wow. Cant believe I did not think of that. Thought it was built into the
master. I’m dumb.
(Régis Hanol) #12
Took me 561 days to fix it but I did it :blush:
(Eli the Bearded) #13
Trying out the examples from the first post:
while (true)
(Régis Hanol) #14
