SSL Problems with Facebook-Auth
(Daniel Nevoigt) #1
Hello at all,
I am getting problems with Facebook-Auth for my discourse installation. I have setup everything like in tutorials said, facebook app also setup with everything needed. When clicking on register and chosing facebook the following error comes:
Than, when clicking ok, I get following notice from my discourse installation:
Means: Sorry, there was an error auth your account. Did you perhaps deny authorisation?
The installation is completely running on ssl, I don´t know how it can be possible that facebook is crying about insecure connection. When adding google auth I had the same issue, but at google I could set http for the callback adress and it worked. So there is somehow a problem with my configuration I guess, but I don´t know where and what I can do…
Discourse is running as docker image on a Ubuntu 16.04 system, Let´s Encrypt SSL Cert.
I would be really happy if someone could help me with that problem.
Thanks a lot in advance.
Daniel
(Frederik L) #2
Did you specify https in the facebook settings?
So all links back to your forum is using: https://
(Daniel Nevoigt) #3
Yes, just checked again, all links are using https://
(Daniel Nevoigt) #4
When going through admin error logs, I can see following error:
I don´t think it has to do with actuall arror, but better post it.
EDIT ++ additional info:
(Joshua Rosenfeld) #5
Have you enabled force https in site settings?
(Daniel Nevoigt) #6
Yes, it is also enabled.
EDIT:
Well, now I logged my Admin Account off which was logged in since yesterday when I was activating that force https. I wanted to try registration via Facebook with other brwoser. Still does not work, also now I cannot login the admin anymore. When trying to login I get redirected to forum without ssl and nothing happens when using Firefox, with Internet Explorer and Chrome it says: Unknown Error
(Daniel Nevoigt) #7
Ok, so to regain access I had to disable force https in rails settings.
Now I am at starting point. Is anyone able to help with that problem?
(Daniel Nevoigt) #8
I have now also problems with mixed content warnings and the preview of editor is not working because of that, when using https. Well, following I will write again everything I have spotted with that installation, in hope someone is willing to help me out.
  • Discourse is running in a Docker container
  • In plesk I enabled Let´s Encrypt + force redirect 301 http to https
  • In admin force https is not working, after that I cannot login anymore
  • When on https preview of editor is not working because he wants to load scripts from insecured connections
  • Facebook login/register also does not work, comes with above posted error because it probably loads something with http
  • Docker proxy rule is set up
My app.yml looks like that:
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
#  - "templates/web.ssl.template.yml"
#  - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "7900:80"   # http
params:
  #db_shared_buffers: "256MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  #UNICORN_WORKERS: 3
  DISCOURSE_HOSTNAME: 'my.forum.url'
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'user1@example.com'
  LETSENCRYPT_ACCOUNT_EMAIL: 'user1@example.com'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  DISCOURSE_SMTP_ADDRESS: "my.ip.address"         # required
  DISCOURSE_SMTP_PORT: 25                        # (optional, default 587)
  DISCOURSE_SMTP_USER_NAME: "my.email.address"      # required
  DISCOURSE_SMTP_PASSWORD: "my.password"               # required, WARNING the char '#' in pw can cause problems!
  DISCOURSE_SMTP_ENABLE_START_TLS: false           # (optional, default true)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  #LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
  ## The CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  #DISCOURSE_CDN_URL: //discourse-cdn.example.com
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/davidtaylorhq/discourse-whos-online.git
          - git clone https://github.com/discourse/discourse-solved.git
          - git clone https://github.com/gdpelican/babble.git
          - git clone https://github.com/discourse/discourse-staff-notes.git
          - git clone https://github.com/angusmcleod/discourse-events.git
run:
So, thats everything I know :slight_smile: Please help me to get it running with SSL finally. I think that also should fix up the problem with Facebook Auth…
Again thank you very much in advance!
Daniel
(Felix Freiberger) #9
So there is a proxy in front of Discourse? Which headers are you passing to Discourse?
(Daniel Nevoigt) #10
@fefrei I have not setup that installation, could you please tell me, where I can see which headers I am passing to Discourse?
(Felix Freiberger) #11
Is Nginx installed and running on your server (outside of Discourse’s container)? If not, can you find out which process is listening on ports 80 and 443?
(Daniel Nevoigt) #12
When I remember right my friend told me he had installed nginx inside, because there was a problem outside plesk related, but I am not sure atm.
The following stuff I could find out:
/var/discourse/templates$ lsof -i :80
COMMAND     PID  USER   FD   TYPE  DEVICE SIZE/OFF NODE NAME
docker-pr 48583  root    6u  IPv4 5498423      0t0  TCP 172.17.0.1:44224->172.17.0.2:http (ESTABLISHED)
docker-pr 48583  root    9u  IPv4 5498435      0t0  TCP 172.17.0.1:44230->172.17.0.2:http (ESTABLISHED)
nginx     52743 nginx   41u  IPv4 3791715      0t0  TCP server.***.com:http (LISTEN)
nginx     55224  root   41u  IPv4 3791715      0t0  TCP server.***.com:http (LISTEN)
/var/discourse/templates$ lsof -i :443
gunicorn 29738 allianceserver   17u  IPv4 4963001      0t0  TCP server.***.com:36378->164.214.186.35.bc.googleusercontent.com:https (CLOSE_WAIT)
gunicorn 29740 allianceserver   19u  IPv4 4963090      0t0  TCP server.***.com:36440->164.214.186.35.bc.googleusercontent.com:https (CLOSE_WAIT)
celery   29748 allianceserver   14u  IPv4 5485875      0t0  TCP server.***.com:51096->164.214.186.35.bc.googleusercontent.com:https (CLOSE_WAIT)
nginx    52743          nginx    4u  IPv4 5470918      0t0  TCP server.***.com:https->p2E568B87.dip0.t-ipconnect.de:57289 (ESTABLISHED)
nginx    52743          nginx   40u  IPv4 3791714      0t0  TCP server.***.com:https (LISTEN)
nginx    52743          nginx   48u  IPv4 5472043      0t0  TCP server.***.com:https->p2E568B87.dip0.t-ipconnect.de:57325 (ESTABLISHED)
nginx    55224           root   40u  IPv4 3791714      0t0  TCP server.9***.com:https (LISTEN)
Allianceserver is a software called Alliance Auth for Eve Online, which is like an authentication service for players, to login with the ingame accounts. Hope that helps.
(Daniel Nevoigt) #13
Well, I was trying the last days, and reading and learning :slight_smile:
I did understand that running Discourse in a Plesk Environment is a bit tricky, so the people say. To be honest, I could not rebuild that install I have actually on my server. But I have more information and the right ones, I hope at least.
(When trying to rebuild that install on a local test environment I allways ended up in a 502 Bad Gateway response from Nginx, so I am still missing one point my mate was doing when setting it up. I can reach the working installation when entering the domain or ip + :(Port), but when enabling the Plesk Nginx Proxy Setting, I get those errors.)
Well, thats not the point for that theme, here I am trying to set up that running environment using ssl without errors.
So as mentioned above we have:
expose:
  - "7900:80"   # http
But why was he not exposing the https port too?
The second question is about the templaes called in app.yml.
Both are outcommented, why?
My question now is, what happens when I expose the https port too? For example:
expose:
  - "7900:80"   # http
  - "9443:443"   # https
Than as second option, enable those ssl templates and rebuild the app. What will I get out of that? Will that work for me? To remember, I had ssl working, but I could not activate force https in admin, + I got errors from mixed content, preview of editor was not working, either the auth callbacks for google and facebook.
Please, could someone point me to the right direction? I also don´t want to try end error on that installation, as it is working for me without ssl.
Cheers, Dan
