SSO Avatar Override Issues
#1
I’m try to get the avatar override to work for my SSO. I’ve tried two things and neither have worked;
Try 1 - Adding avatar info to payload
   Subscriber s = new SubscriberFactory().GetObjectByEmail(email);
    if ( s != null )
       avatarInfo = "&avatar_force_update=true";
        avatarInfo += "&avatar_url=" + "http://www.stackfish.com/" + s.AvatarUrl;
            string returnPayload = "nonce=" + HttpUtility.UrlEncode(nonce) +
                                    "&email=" + HttpUtility.UrlEncode(email) +
                                    "&external_id=" + HttpUtility.UrlEncode(externalId) +
                                    "&username=" + HttpUtility.UrlEncode(username) +
                                    "&name=" + HttpUtility.UrlEncode(name) + avatarInfo;
This results in an error that breaks my SSO
Try 2: Tacking on that avatar info at end of the redirect URL
 redirectUrl +=  "sso=" + encodedPayload + "&sig=" + returnSig + avatarInfo;
This doesn’t break my SSO but avatars are not overwritten.
I have Overides user avatar… checked in my admin panel.
Does anyone know what I’m doing wrong?
Thanks
(Kane York) #2
What happens if you pass a hash into a form-encoding helper? You’ve got your string types mixed together all over the place.
#3
Thanks riking that was a problem and I’m one step closer. I’m assuming Try 1 is the correct approach.
I’ve updated my code to be:
if ( s != null )
                avatarInfo += "&avatar_url=" + "http://www.stackfish.com" + s.AvatarUrl;
            addLog("SSOLogin: AvatarInfo Before Encode: " + avatarInfo);
            avatarInfo = HttpUtility.UrlEncode(avatarInfo);
I’ve also confirmed through logging that I’m passing a valid avatar url:
avatar_url=http://www.stackfish.com/Portals/0/UserImages/AvatarImage20207da8ae19-7c9e-4f58-ba60-53043944b944.jpg
WIth this approach, I can log in with my SSO but my avatar is still the default discourse avatar. Am I missing a setting?
#4
I found some more encoding issues on my part. I’ve modified my code to be:
   if ( s != null )
                avatarInfo += "&avatar_url=" + HttpUtility.UrlEncode("http://www.stackfish.com" + s.AvatarUrl) ;
and here is a pretty print of what I’m passing to discourse:
nonce=8a82d4e93c2a9da7625e83ff7f4f2801
&email=jimmy%40stackfish.com&external_id=115
&username=jimmy%40stackfish.com
&name=Jimmy
&avatar_url=http%3a%2f%2fwww.stackfish.com%2fPortals%2f0%2fUserImages%2fAvatarImage20207da8ae19-7c9e-4f58-ba60-53043944b944.jpg
Now my SSO is broke with the error: Job exception: undefined method ‘to_i’ for true:TrueClass
#5
If found a thread that mentioned that avatar_force_update need to be either 1 or ‘true’.
I set it to 1 and it now works.
