SSO does not open new window
(Charles Han) #1
SSO does not open new window. Is this the default behavior? If so, how do I make it so that Login button opens up a new window?
https://forum.orosim.com/
(Sam Saffron) #2
Yes, default and only behavior is not open a new window. The window messaging trick that is implemented for Google/Facebook etc logins is not implemented for SSO.
I would be ok with adding this as an option.
(Charles Han) #3
Oh… I used https://forums.meteor.com/ which uses meteor.com as SSO and I thought login through a new window was the default behavior. @sam can you think of a simple way to add this on top of your head?
(Sam Saffron) #4
Easy … no… you would either need to make a new auth provider plugin, or submit a PR to improve SSO.
