SSO does not redirect, is canceled instead
(Bgoldste) #1
Hi all! Am trying to get SSO set up with our domain. When I click login, nothing happens. In chrome inspector, I see that the request is getting cancelled and no redirect is happening:
sso?return_path=%2F GET (canceled) application-2744e9ff8c515050f35b1b6f8fd5b476.js:34 0 B 90 ms
I can’t really start getting this setup until I know how the actual redirect works. My plan was to have this send to a /sso on our server, print out the request, and then code from there.
Any ideas, help? Thanks!
(Kane York) #2
There are pretty thorough explanations here: Official Single-Sign-On for Discourse (sso)
Or you could use one of the implementations that already exist.
(Bgoldste) #3
the issue was using local host as a dev env
