SSO redirect to
I am using discourse as an sso provider to wordpress. Meaning discourse handles all user authentication (login, signup, profile, etc…)
How do I set it up so that when a user logs in from wordpress and sent to the forum for login, they get redirected back to the page they were on. Because right now after a user logs in no matter where on the site they were, they get sent back to the home page of my WP site
If you use the [discourse_sso_client] shortcode, it will create a login link for you that should redirect users back to the WordPress page that they clicked the login link on. Note, the [discourse_sso_client] shortcode will not display a link for users who are already logged into your site.
You can also create a link yourself that should redirect users to a specified WordPress page after logging in through Discourse. Set the redirect_to value to the URL of the WordPress page you want people to end up on.
<a href="http://wpdiscourse.test/?discourse_sso=1&redirect_to=http://wpdiscourse.test/my-blog-post">Log in with Discourse</a>
So its not possible to redirect to the page the user was originally on?
Yes, you can either do that yourself by writing some code that will detect what page the user is on and then using that value to set the redirect_to parameter, or you can use the shortcode. The shortcode should take care of setting the redirect for you.
