Stable Discourse 2.2.6 - Can't Post Topics
After upgrading two forums from the previous stable version to the current stable version 2.2.6, posting new topics doesn’t work on both and gives an internal server error.
Getting errors like:
NoMethodError (undefined method each_upload_url’ for #Post:XXXXXXXX) /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activemodel-5.2.2.1/lib/active_model/attribute_methods.rb:430:in met
Job exception: undefined method each_upload_url’ for #Post:XXXXXXX`
Just a heads up.
Edit: Just spotted this on the git repo:
Probably related:
Can you provide us with the full stack trace?
Fix: I changed one of the forums from the stable branch to beta. After upgrading (v2.3.0.beta11 +487) the problem is gone, so it appears the problem is fixed in later versions. I believe it is an issue with the 2.2.6 stable version.
Thanks @tgxworld I’m not sure how to provide the full stack trace, if it is still useful to you after the update above and you’re able to let me know how to provide it - I’d be happy to.
There should be a backtrace tab when you’re looking at the error.
Screenshot%20from%202019-06-12%2014-47-04
@tgxworld Got it, cheers!
So for the error type:
Job exception: undefined method each_upload_url’ for #Post:0x0000XXXXXX`
Backtrace:
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activemodel-5.2.2.1/lib/active_model/attribute_methods.rb:430:in `method_missing'
/var/www/discourse/plugins/discourse-topic-previews/lib/post_edits.rb:5:in `link_post_uploads'
/var/www/discourse/lib/cooked_post_processor.rb:48:in `block in post_process'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:5:in `synchronize'
/var/www/discourse/lib/cooked_post_processor.rb:37:in `post_process'
/var/www/discourse/app/jobs/regular/process_post.rb:24:in `execute'
/var/www/discourse/app/jobs/base.rb:137:in `block (2 levels) in perform'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.0.6/lib/rails_multisite/connection_management.rb:63:in `with_connection'
/var/www/discourse/app/jobs/base.rb:127:in `block in perform'
/var/www/discourse/app/jobs/base.rb:123:in `each'
/var/www/discourse/app/jobs/base.rb:123:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:187:in `execute_job'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:169:in `block (2 levels) in process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/middleware/chain.rb:128:in `block in invoke'
/var/www/discourse/lib/sidekiq/pausable.rb:81:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/middleware/chain.rb:130:in `block in invoke'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/middleware/chain.rb:133:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:168:in `block in process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:139:in `block (6 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/job_retry.rb:98:in `local'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:138:in `block (5 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq.rb:36:in `block in <module:Sidekiq>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:134:in `block (4 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:199:in `stats'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:129:in `block (3 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/job_logger.rb:8:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:128:in `block (2 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/job_retry.rb:73:in `global'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:127:in `block in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/logging.rb:48:in `with_context'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/logging.rb:42:in `with_job_hash_context'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:126:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:167:in `process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:85:in `process_one'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:73:in `run'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/util.rb:16:in `watchdog'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.1.3/lib/sidekiq/util.rb:25:in `block in safe_thread'
And the other:
NoMethodError (undefined method `each_upload_url' for #<Post:0x0000XXXXXXX>) /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activemodel-5.2.2.1/lib/active_model/attribute_methods.rb:430:in `met
Backtrace:
/var/www/discourse/lib/post_creator.rb:351:in `link_post_uploads'
/var/www/discourse/lib/post_creator.rb:175:in `block in create'
/var/www/discourse/lib/post_creator.rb:335:in `block (2 levels) in transaction'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:259:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:239:in `block in within_new_transaction'
/usr/local/lib/ruby/2.6.0/monitor.rb:230:in `mon_synchronize'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:236:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:259:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.2.1/lib/active_record/transactions.rb:212:in `transaction'
/var/www/discourse/lib/post_creator.rb:334:in `block in transaction'
/var/www/discourse/lib/post_creator.rb:333:in `transaction'
/var/www/discourse/lib/post_creator.rb:165:in `create'
/var/www/discourse/lib/new_post_manager.rb:204:in `perform_create_post'
/var/www/discourse/lib/new_post_manager.rb:178:in `perform'
/var/www/discourse/app/controllers/posts_controller.rb:185:in `create'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/abstract_controller/base.rb:194:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_controller/metal/rendering.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.2.1/lib/active_support/callbacks.rb:132:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/abstract_controller/callbacks.rb:41:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_controller/metal/rescue.rb:22:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.2.1/lib/active_support/notifications.rb:168:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.2.1/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.2.1/lib/active_support/notifications.rb:168:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.2.1/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/abstract_controller/base.rb:134:in `process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionview-5.2.2.1/lib/action_view/rendering.rb:32:in `process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.0.1/lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_controller/metal.rb:191:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_controller/metal.rb:252:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_dispatch/journey/router.rb:35:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_dispatch/journey/router.rb:35:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_dispatch/routing/route_set.rb:840:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-protection-2.0.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:32:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.6/lib/rack/tempfile_reaper.rb:15:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.6/lib/rack/conditional_get.rb:38:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.6/lib/rack/head.rb:12:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:216:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:232:in `context'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:226:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.2.1/lib/active_support/callbacks.rb:98:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/logster-2.0.1/lib/logster/middleware/reporter.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.2.1/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.2.1/lib/rails/rack/logger.rb:28:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:16:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.6/lib/rack/method_override.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.2.1/lib/action_dispatch/middleware/executor.rb:14:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.6/lib/rack/sendfile.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.0.1/lib/mini_profiler/profiler.rb:171:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/message_bus-2.2.0.pre.1/lib/message_bus/rack/middleware.rb:57:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:182:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.2.1/lib/rails/engine.rb:524:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.2.1/lib/rails/railtie.rb:190:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.2.1/lib/rails/railtie.rb:190:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.6/lib/rack/urlmap.rb:68:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in `start'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.4.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `<main>'
The discourse-topic-previews plugin is calling a new function which doesn’t exist in v2.2.
If you really want to stay on stable, they did say they plan to publish v2.3 next Monday. But stable + mods will continue to be a risk.
@markersocial Yup confirmed to be the discourse-topic-previews plugin.
https://github.com/angusmcleod/discourse-topic-previews/blob/master/lib/post_edits.rb
You’ll either need to run on latest or disable the plugin for now. Not sure how easy it will be for @angus to make it backwards compatible.
Thanks guys. @merefield thoughts on the above?
