Start Discourse on Boot
unsupported-install
(MorphZan) #1
Hi Guys
I am running Discourse on an Ubuntu Install and would like to know how I go about getting it to run the following commands on startup so that if my server reboots I dont need to SSH in to start up Discourse:
cd ~/discourse
bundle exec rails server --binding=0.0.0.0
(Sam Saffron) #2
To start on boot use our official docker install
(MorphZan) #3
Does this require me to reinstall from scratch?
(Sam Saffron) #4
It requires you to install following our official guide at discourse/INSTALL.md at master · discourse/discourse · GitHub
(MorphZan) #5
Thank you :slight_smile:
Will give it try tomorrow!!!
(ljpp) #6
Hijacking a thread a little, but I’ve noticed something a couple of times and this is not worth its own topic.
I sometimes:
./launcher rebuild app && reboot
However the following start on boot has failed for me a couple of times. Non-fatal issue as stopping and starting the container has done the trick.
Odd thing, though. Linux should reboot gracefully.
(Sam Saffron) #7
You need to confirm you are on the latest version of docker. If so, and if you can reproduce the issue a ticket should be raised with docker.
All we do is tell docker to restart=always so it should be taking care of this.
(Jay Pfaffman) #8
I don’t know whether it’s related, but if you do a shutdown -r rather than a reboot it will shut down more gracefully.
(ljpp) #9
Yeah, or maybe adding a little wait after rebuild.
@sam Yep latest. Actually got this yesterday when I was doing a fresh install (Ubu 16.04).
