Stuck on "bundle exec rake multisite:migrate"..help
I just update my installation using the Web Updater: /admin/upgrade/#/upgrade/discourse
Now it’s stuck here:
Been that for 20 minutes more.
What should I do?
I visit /admin/upgrade/#/ on another tab and it showing:
This seems to be the same issue:
Yes I need to run it twice to fix it.
Again for today I encounter the same problem.
But now happens while updating “docker_manager”.
Any way I can prevent this from happening in the future?
Seems web upgrade has some bug, that only via CLI upgrade is the way to go.
The commit that was causing this had been reverted and I can confirm that if You rebuild once again now, this won’t come again.
