Serve Discourse from a subfolder (path prefix) instead of a subdomain
Thank you so much for your response @pfaffman, I really appreciate it.
Digging deeper into this, I’ve tried to revert all the changes in /etc/nginx/conf.d/discourse.conf inside the container, entering into it with /var/discourse/launcher enter app.
After reverting the discourse.conf file I did a rebuild, using /var/discourse/launcher rebuild app.
I’ve tried to access to the website, without /forum but the same "Oops " error appear (the first image I attached in my previous comment).
Also, I’ve tried to execute (inside the container):
RAILS_ENV=production bundle exec script/discourse remap '/forum/uploads' '/uploads'
inside the container, but another error has appeared (I think is the same that @ahmed_khan1 has highlighted):
bundler: failed to load command: script/discourse (script/discourse)
Traceback (most recent call last):
	73: from /usr/local/bin/bundle:25:in `<main>'
	72: from /usr/local/bin/bundle:25:in `load'
	71: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/exe/bundle:36:in `<top (required)>'
	70: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/friendly_errors.rb:103:in `with_friendly_errors'
	69: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/exe/bundle:48:in `block in <top (required)>'
	68: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli.rb:25:in `start'
	67: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
	66: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli.rb:31:in `dispatch'
	65: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
	64: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
	63: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
	62: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli.rb:484:in `exec'
	61: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli/exec.rb:23:in `run'
	60: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli/exec.rb:58:in `kernel_load'
	59: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli/exec.rb:58:in `load'
	58: from script/discourse:290:in `<top (required)>'
	57: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/base.rb:485:in `start'
	56: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor.rb:392:in `dispatch'
	55: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/invocation.rb:127:in `invoke_command'
	54: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/command.rb:27:in `run'
	53: from script/discourse:37:in `remap'
	52: from script/discourse:270:in `load_rails'
	51: from script/discourse:270:in `require'
	50: from /var/www/discourse/config/environment.rb:7:in `<top (required)>'
	49: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/railtie.rb:207:in `method_missing'
	48: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/railtie.rb:207:in `public_send'
	47: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/application.rb:391:in `initialize!'
	46: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:60:in `run_initializers'
	45: from /usr/local/lib/ruby/2.7.0/tsort.rb:205:in `tsort_each'
	44: from /usr/local/lib/ruby/2.7.0/tsort.rb:226:in `tsort_each'
	43: from /usr/local/lib/ruby/2.7.0/tsort.rb:347:in `each_strongly_connected_component'
	42: from /usr/local/lib/ruby/2.7.0/tsort.rb:347:in `call'
	41: from /usr/local/lib/ruby/2.7.0/tsort.rb:347:in `each'
	40: from /usr/local/lib/ruby/2.7.0/tsort.rb:349:in `block in each_strongly_connected_component'
	39: from /usr/local/lib/ruby/2.7.0/tsort.rb:415:in `each_strongly_connected_component_from'
	38: from /usr/local/lib/ruby/2.7.0/tsort.rb:415:in `call'
	37: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:50:in `tsort_each_child'
	36: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:50:in `each'
	35: from /usr/local/lib/ruby/2.7.0/tsort.rb:421:in `block in each_strongly_connected_component_from'
	34: from /usr/local/lib/ruby/2.7.0/tsort.rb:431:in `each_strongly_connected_component_from'
	33: from /usr/local/lib/ruby/2.7.0/tsort.rb:422:in `block (2 levels) in each_strongly_connected_component_from'
	32: from /usr/local/lib/ruby/2.7.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
	31: from /usr/local/lib/ruby/2.7.0/tsort.rb:228:in `block in tsort_each'
	30: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:61:in `block in run_initializers'
	29: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:32:in `run'
	28: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:32:in `instance_exec'
	27: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:633:in `block in <class:Engine>'
	26: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:633:in `each'
	25: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:634:in `block (2 levels) in <class:Engine>'
	24: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:680:in `load_config_initializer'
	23: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/notifications.rb:205:in `instrument'
	22: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:681:in `block in load_config_initializer'
	21: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:326:in `load'
	20: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:299:in `load_dependency'
	19: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:326:in `block in load'
	18: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:60:in `load'
	17: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:60:in `load'
	16: from /var/www/discourse/config/initializers/004-message_bus.rb:122:in `<main>'
	15: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/model_schema.rb:380:in `table_exists?'
	14: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_handling.rb:283:in `connection'
	13: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_handling.rb:327:in `retrieve_connection'
	12: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:1128:in `retrieve_connection'
	11: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:428:in `connection'
	10: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:588:in `checkout'
	 9: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:866:in `acquire_connection'
	 8: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:905:in `try_to_checkout_new_connection'
	 7: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:926:in `checkout_new_connection'
	 6: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:882:in `new_connection'
	 5: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:882:in `public_send'
	 4: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/postgresql_adapter.rb:37:in `postgresql_connection'
	 3: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/postgresql_adapter.rb:78:in `new_client'
	 2: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/pg-1.2.3/lib/pg.rb:58:in `connect'
	 1: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/pg-1.2.3/lib/pg.rb:58:in `new'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/pg-1.2.3/lib/pg.rb:58:in `initialize': connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: FATAL:  Peer authentication failed for user "discourse" (PG::ConnectionBad)
	71: from /usr/local/bin/bundle:25:in `<main>'
	70: from /usr/local/bin/bundle:25:in `load'
	69: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/exe/bundle:36:in `<top (required)>'
	68: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/friendly_errors.rb:103:in `with_friendly_errors'
	67: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/exe/bundle:48:in `block in <top (required)>'
	66: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli.rb:25:in `start'
	65: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
	64: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli.rb:31:in `dispatch'
	63: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
	62: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
	61: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
	60: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli.rb:484:in `exec'
	59: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli/exec.rb:23:in `run'
	58: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli/exec.rb:58:in `kernel_load'
	57: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli/exec.rb:58:in `load'
	56: from script/discourse:290:in `<top (required)>'
	55: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/base.rb:485:in `start'
	54: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor.rb:392:in `dispatch'
	53: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/invocation.rb:127:in `invoke_command'
	52: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/command.rb:27:in `run'
	51: from script/discourse:37:in `remap'
	50: from script/discourse:270:in `load_rails'
	49: from script/discourse:270:in `require'
	48: from /var/www/discourse/config/environment.rb:7:in `<top (required)>'
	47: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/railtie.rb:207:in `method_missing'
	46: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/railtie.rb:207:in `public_send'
	45: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/application.rb:391:in `initialize!'
	44: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:60:in `run_initializers'
	43: from /usr/local/lib/ruby/2.7.0/tsort.rb:205:in `tsort_each'
	42: from /usr/local/lib/ruby/2.7.0/tsort.rb:226:in `tsort_each'
	41: from /usr/local/lib/ruby/2.7.0/tsort.rb:347:in `each_strongly_connected_component'
	40: from /usr/local/lib/ruby/2.7.0/tsort.rb:347:in `call'
	39: from /usr/local/lib/ruby/2.7.0/tsort.rb:347:in `each'
	38: from /usr/local/lib/ruby/2.7.0/tsort.rb:349:in `block in each_strongly_connected_component'
	37: from /usr/local/lib/ruby/2.7.0/tsort.rb:415:in `each_strongly_connected_component_from'
	36: from /usr/local/lib/ruby/2.7.0/tsort.rb:415:in `call'
	35: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:50:in `tsort_each_child'
	34: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:50:in `each'
	33: from /usr/local/lib/ruby/2.7.0/tsort.rb:421:in `block in each_strongly_connected_component_from'
	32: from /usr/local/lib/ruby/2.7.0/tsort.rb:431:in `each_strongly_connected_component_from'
	31: from /usr/local/lib/ruby/2.7.0/tsort.rb:422:in `block (2 levels) in each_strongly_connected_component_from'
	30: from /usr/local/lib/ruby/2.7.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
	29: from /usr/local/lib/ruby/2.7.0/tsort.rb:228:in `block in tsort_each'
	28: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:61:in `block in run_initializers'
	27: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:32:in `run'
	26: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:32:in `instance_exec'
	25: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:633:in `block in <class:Engine>'
	24: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:633:in `each'
	23: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:634:in `block (2 levels) in <class:Engine>'
	22: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:680:in `load_config_initializer'
	21: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/notifications.rb:205:in `instrument'
	20: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:681:in `block in load_config_initializer'
	19: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:326:in `load'
	18: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:299:in `load_dependency'
	17: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:326:in `block in load'
	16: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:60:in `load'
	15: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:60:in `load'
	14: from /var/www/discourse/config/initializers/004-message_bus.rb:122:in `<main>'
	13: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/model_schema.rb:380:in `table_exists?'
	12: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_handling.rb:283:in `connection'
	11: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_handling.rb:327:in `retrieve_connection'
	10: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:1128:in `retrieve_connection'
	 9: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:428:in `connection'
	 8: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:588:in `checkout'
	 7: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:866:in `acquire_connection'
	 6: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:905:in `try_to_checkout_new_connection'
	 5: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:926:in `checkout_new_connection'
	 4: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:882:in `new_connection'
	 3: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:882:in `public_send'
	 2: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/postgresql_adapter.rb:37:in `postgresql_connection'
	 1: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/postgresql_adapter.rb:77:in `new_client'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/postgresql_adapter.rb:81:in `rescue in new_client': connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: FATAL:  Peer authentication failed for user "discourse" (ActiveRecord::NoDatabaseError)
So I’m not sure what more I can do :confused:
How to edit nginx/discourse.conf
I assume any changes to discourse.conf inside the container get reverted by doing a rebuild anyway.
To keep changes you must some-how add them to your container configuration - e.g. web_only.yml:
## Remember, this is YAML syntax - you can only have one block with a name
run:
  - replace:
      filename: /etc/nginx/conf.d/discourse.conf
      to: $http_x_real_ip
      global: true
How to debug a sub-folder Discourse install
In a Discourse sub-folder install a call to Discourse goes like this:
example.org/forum[External proxy for example.org]/path-to-discourse/discourse/shared/web-only/nginx.http.sock[Nginx in Discourse web-container]
So if there is an error, we must first locate it:
  • External proxy
  • Nginx in Discourse container
  • Discourse itself
External proxy
  • Call it in a browser and check result.
  • Check error logs of external proxy.
  1. SSH into your webserver.
  2. Directly connect to socket via curl.
  3. Debug curl output and logs of Nginx in Discourse
Important: use http url – and not https.
curl -I --unix-socket /path-to-discourse/discourse/shared/web-only/nginx.http.sock http://www.example.org/forum/
If this works, try a real call like:
curl --unix-socket /path-to-discourse/discourse/shared/web-only/nginx.http.sock \
-H "user-agent: Chrome/88.0.4324.182" \
-H "Accept-Encoding: gzip" \
http://www.example.org/forum/t/test-thread/12345 --output test-encoded.html.gz
He @pfaffman and @rrit,
I have some more insights about the problem. In the Discourse log, as @pfaffman said:
the error thrown is:
Started GET "/" for XX.XX.XX.XX at 2022-02-07 10:51:02 +0000
Processing by ListController#latest as HTML
  Rendered list/list.erb within layouts/application (Duration: 12.4ms | Allocations: 4137)
  Rendered layout layouts/application.html.erb (Duration: 23.6ms | Allocations: 8794)
Completed 500 Internal Server Error in 343ms (ActiveRecord: 0.0ms | Allocations: 62982)
ActionView::Template::Error (undefined method `[]' for nil:NilClass)
lib/svg_sprite/svg_sprite.rb:501:in `block in custom_icons'
lib/svg_sprite/svg_sprite.rb:500:in `each'
lib/svg_sprite/svg_sprite.rb:500:in `custom_icons'
lib/svg_sprite/svg_sprite.rb:275:in `block in all_icons'
lib/distributed_cache.rb:25:in `defer_get_set'
lib/svg_sprite/svg_sprite.rb:516:in `get_set_cache'
lib/svg_sprite/svg_sprite.rb:268:in `all_icons'
lib/svg_sprite/svg_sprite.rb:337:in `bundle'
lib/svg_sprite/svg_sprite.rb:285:in `block in version'
lib/svg_sprite/svg_sprite.rb:284:in `version'
lib/svg_sprite/svg_sprite.rb:290:in `path'
app/helpers/application_helper.rb:586:in `client_side_setup_data'
app/views/layouts/application.html.erb:61
lib/topic_list_responder.rb:13:in `block (2 levels) in respond_with_list'
lib/topic_list_responder.rb:9:in `respond_with_list'
app/controllers/list_controller.rb:103:in `block (2 levels) in <class:ListController>'
app/controllers/application_controller.rb:387:in `block in with_resolved_locale'
app/controllers/application_controller.rb:387:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:71:in `call'
lib/middleware/anonymous_cache.rb:356:in `call'
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
lib/middleware/enforce_hostname.rb:23:in `call'
lib/middleware/request_tracker.rb:198:in `call'
ActionController::RoutingError (No route matches [GET] "/service-worker-cce5f3834b22e40a87291d786315f7def48e1456ba24fe116a16d5a38af4012a.js")
Job exception: uninitialized constant DiscourseAlgolia::UserIndexer::SETTINGS
Did you mean?  String
Is this ringing a bell for you?
Btw, @rrit I’ve tried to search the nginx.http.sock file, in the folder you suggested and also in the whole project, but I didn’t found, so I was not able to try what you said :confused:
Regards,
Miguel.
At this one I can’t really tell what you’ve done or what you’re trying to do.
I guess you don’t have a backup of your last working database and yml file?
I think what I would do is try to get back to your last setup, take a backup and then start over on a test site.
Sorry, I was referencing to a setup like this:
Container config web_only.yml:
templates:
  - "templates/web.socketed.template.yml"
#expose:
#  - "80:80"   # http
#  - "443:443" # https
External nginx-site.conf:
server {
    listen 443 ssl default_server;
    location ~ ^/forum {
        proxy_pass http://unix:/path-to-discourse/discourse/shared/web-only/nginx.http.sock:;
        proxy_set_header Host $http_host;
        proxy_http_version 1.1;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header X-Forwarded-Proto https;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header Accept-Encoding $http_accept_encoding;
Thanks for the response @pfaffman. To be honest, I don’t have a backup because it was a test instance. So it’s not a big deal and I was able to start a new instance with the subdomain approach.
But I’m still curious about the error I said when the command:
is executed.
Would you have any insight about the error?
So you want to be able to switch back and forth between a subfolder and not subfolder installation? I don’t recommend it. And mostly nobody thinks that a subfolder installation is a good idea.
