Syntax highlighting of code blocks
(croaky) #1
We have a pretty technical forum with frequent code blocks. We need some color in our lives!
highlight.js is pretty awesome for this. Here’s an example of highlight.js in action:
(Chris Hunt) #2
Don’t we have this? :smiley:
def stolen_from_thoughtbot
  big_cities = ['New York, NY', 'Boston, MA', 'San Francisco, CA'] # long list of cities
  big_cities.each do |city|
    Location.near(city, 50).each do |location|
      LocationSerializer.new(location).serializable_hash
(Sam Saffron) #3
Have you seen this?
def hello
   puts "world"
```ruby
def hello
   puts "world"
What we really need to do is add a setting to bind the “computer” glyph to create GitHub style blocks vs the pre style blocks it does out of the box
PRs totally welcome in this area.
(Ben Orenstein) #4
Dumb question, but how can display the fenced code block without interpolation like you’ve done here?
I want to include instructions for using fenced code block in my welcome message, but I can’t get Discourse to stop interpolating my “tick-tick-tick-ruby” string.
(Régis Hanol) #5
You need to select your code and either clic on the code sample button on the toolbar or press Ctrl+K.
You can alternatively add 4 whitespaces before each line.
(Sam Saffron) #6
Yeah what @zogstrip said
I think we should amend the help text there from “Code sample” to “Pre-formatted text”, we also need an extra icon for code sample (default off, but that can be enabled from the site settings).
Feeling brave with a PR ? :slight_smile:
(Ben Orenstein) #7
I’m afraid you’ve misunderstood me.
I want to teach my users how to do language-specific highlighting in Discourse. So I want to write a post where I tell them how to do it.
The problem is, if I write out “tick-tick-tickruby” in a post, Discourse sees that and removes it, thinking I want to show some code.
I want to know how to include the literal string that one uses to fence a code block without having Discourse interpolate it.
@sam did this above. First we see the highlighted code, then we see what a user would type to achieve it.
How do I display the text a user would type to highlight code without it being “eaten” by Discourse?
(edited by @zogstrip)
Like this:
```ruby
foo = bar
(Régis Hanol) #8
I just edited your post so that you can see how to do it. Hope it clears it up!
(Jeff Atwood) #9
You just indent by 4 spaces. See Markdown Editing Help - Super User
(Ben Orenstein) #10
Ahh, got it now.
Thanks!
(Chase Sterling) #11
Hmm, I’m having trouble getting the backticks preformatted as well. When indenting the whole block 4 spaces it just ends up indenting my formatted code more. I have included a screen shot of the problem:
I’d like the backticks to be included in rendered page for users to see.
A button to insert the backticks from the post editor would be nice too.
Bug with the cursor and image
(Jeff Atwood) #12
Indent 8 spaces there, not 4. The first 4 just indicate “this block is a part of the bullet”.
See:
  • this is a list
  • another list item
     tasks:
        atask: {}
  • here is another list item
Click here to see the raw markup for this post.
https://meta.discourse.org/raw/7242/12
(Chase Sterling) #14
Aha! Thank you very much, I was totally forgetting about the indents for the bullet items.
(Simon Sarris) #15
Why does syntax highlighting work when I do triple tick: (```)
var test = "aaa"
But not when I do 4 spaces:
var test = "aaa"
It works with 4 spaces on StackOverflow, markdown, so I assumed it would be the same here.
(Jeff Atwood) #16
Because Stack Overflow is a site for coders? Here there is preformatted text and code fences, which did you want?
(Simon Sarris) #17
Ah I see, very sorry. I had assumed there would be some inference built-in as a default for <pre><code> blocks, and that I was doing something wrong.
(Walter Stabosz) #18
What are the supported language names that can follow the opening backticks ?
Also, what does “PR” mean?
(Jens Maier) #19
Pull request. Git has no central repository server; sourcecode is shared by pushing code changes (called commits) to other developers or requesting that another developers should pull some commits from your repository. Github builds a UI around this process.
(Sam Saffron) #20
See: highlight.js demo
(Artem Pelenitsyn) #21
If two ways for making preformatted code (4 spaces vs. code fences) have different effect, why there is only one button in UI (namely, for adding 4 spaces)? How new users suppose to guess about code fences? It would be great to add another button for this (make it optional in admin panel?).
